Coil Repair
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Coil Repair
Post by BobShirleyAtlantaTx » Fri Feb 21, 2020 1:11 am
Is it advisable to insulate the capacitor before repotting tar?
jab35
Last Name: Bartsch
Re: Coil Repair
Post by jab35 » Fri Feb 21, 2020 9:01 am
No, not necessary. If the Cap somehow needed electrical insulation, so would all the bare wires inside the potted assembly. If the rationale is that the Cap needs thermal protection from the hot tar, that .004" layer of fiberglass tape isn't going to do much. In addition to the electrical characteristics of the new Capacitors, these are capable of functioning at high tempereature, not that they should be tested with overheated tar when assembled, but they will be fine after potting. jb
First Name: Keith
Last Name: Townsend
Re: Coil Repair
Post by KWTownsend » Fri Feb 21, 2020 10:30 am
Bob,
Like you, I too use wooden filler blocks to conserve tar.
Keith
