Another question
Mel King
First Name: Melvin
Last Name: King
Another question
Post by Mel King » Fri Feb 21, 2020 10:40 am
I have run into two 1915 trans with brake drums that have the big bushings and the clutch disc drum does not press on and they both were running. Has anybody else run across this? Oh,and they are not worn . MEL.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Re: Another question
Post by R.V.Anderson » Fri Feb 21, 2020 11:00 am
Not sure what you mean by "won't go on." Do you mean that the drum won't fit over the main shaft, or that there is zero clearance between the drum and the bushing flange once it's pressed into place? Also, do you mean that "both cars were running" with exactly the same parts that you are now trying to install?
Mel King
First Name: Melvin
Last Name: King
Post by Mel King » Fri Feb 21, 2020 11:32 am
What I meant is the disc drum slides on the main shaft instead of presses on like the later ones with the three washers .MEL.
Post by RajoRacer » Fri Feb 21, 2020 12:27 pm
ALL clutch disc drums should be a slight interference fit onto the main shaft.
