Convert Kerosene lamp to electric.
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Mon Feb 24, 2020 1:50 pm
I am looking for something like this to hold a dual filament bulb.
Re: Convert Kerosene lamp to electric.
Post by Allan » Mon Feb 24, 2020 5:17 pm
Chris, I made mine using light sockets from 80's Japanese tail light assemblies. any later than that and the lights are all plastic. I bent some fencing wire for the ring and left a leg on one end to get the globe holder in the centre of the lamp. The metal socket was then soldered to the leg. I left the burner assembly in place, so had to feed the wiring through the lamp chimney.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Feb 24, 2020 5:23 pm
I think Bob just posted a new LED conversion for these in the classifieds
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Mon Feb 24, 2020 9:58 pm
I have seen the LED's that Lang's has. Battery powered and no brake light.
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Mon Feb 24, 2020 10:03 pm
I'm not finding anything in the classifieds
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Tue Feb 25, 2020 5:00 am
I made these some time ago, to convert my side lamps to blinkers with LEDs, took a block of i think nylon and made it the same height as the burner assembly, that way the tank holds it in place, the wires go out the slot where the fegulator knob normaly goes, you don't have to butcher a good sidelight and you can convert back to kerosene in about two seconds, only thing is you have to find a way to make the wires look inconspicuous (did i spell that right ??) :roll:
Leo van Stirum, Netherlands
Post by RajoRacer » Tue Feb 25, 2020 11:29 am
You just need one to convert the tail lamp ? I might have the one that used to be available some years back - still in the package - just need to locate it !
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Tue Feb 25, 2020 12:54 pm
Here is how I did mine.
Lamp is 5/21W 12V.
Wiring enters by the chemeny, no hole was drilled.
Andre
Belgium
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Tue Feb 25, 2020 2:45 pm
https://www.mtfca.com/phpBB3/viewtopic.php?f=5&t=10705
my bad, these are for converting carbide headlamps
