Old Photo- 1909 Model T
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Mon Feb 24, 2020 10:21 pm
Model T 1909.JPG (53.1 KiB) Viewed 6232 times
Or is it a 1910?
Sarikatime
Last Name: Seress
Re: Old Photo- 1909 Model T
Post by Sarikatime » Tue Feb 25, 2020 8:42 am
That man is either very small or that is a custom made extra large vehicle. My biggest problem, besides my stomach, these cars are small and the steering wheel is just too far up on me to drive it comfortably. Just my fat two cents worth. Frank
pete eastwood
First Name: Pete
Last Name: Eastwood
Post by pete eastwood » Tue Feb 25, 2020 1:49 pm
It's a 1910, the front body mount has 3 bolts.
The front mount changed from 2 bolts to 3 bolts in early 1910 .
Post by John kuehn » Tue Feb 25, 2020 1:59 pm
It does look as though the driver is no taller than 5’5”. I have black era T’s and they don’t appear as roomy as the car does in this photo. I’m 6’2” and my legs will barely go under the steering wheel.
Post by Rich Eagle » Tue Feb 25, 2020 3:27 pm
From the kinks in the horn tube and the paint chipping on the door jamb I would say that car has had enough use for the seat springs and padding to give less support than when new. He could be siting a few inches lower in the seat now. Also the photo has some odd distortion making the car look longer. He may be a short fellow but other things are affecting what we see.
Post by Norman Kling » Tue Feb 25, 2020 4:27 pm
I would suspect there is a bit of distortion in the photography because everything seems wider than it should and vertically shorter than normal. The man is probably short in stature as well. Notice how long the steering column seems but it quite far from the man. It also seems to be at a lower angle than it should be. Just my thoughts.
Post by Rich Eagle » Tue Feb 25, 2020 4:42 pm
This is closer to the right proportions. Does he look as short?
jiminbartow
Last Name: Patrick
Post by jiminbartow » Tue Feb 25, 2020 4:49 pm
Is it possible that photo was taken in a studio? The car is so big, long and roomy, it appears to be a prop and the background appears to be a painted backdrop. Since the flag has Ford on it, I wouldn’t be surprised if the car prop was located in a Ford dealership as a selling point to show potential buyers how roomy the T is. Jim Patrick
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Tue Feb 25, 2020 9:28 pm
Here are a couple of pics of my 1910. The orientation of the seat and steering wheel look just about the same as in the picture Herb posted.
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Post by FreighTer Jim » Tue Feb 25, 2020 10:12 pm
Note the rare yellow factory slinky
that served to amuse both driver
and front seat passenger .... 👀
Boy KD - you sure are The Greatest .... 😉
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Wed Feb 26, 2020 12:10 pm
Here is my late 09 with us in it. Lots of room behind the wheel.
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Wed Feb 26, 2020 12:26 pm
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Thu Feb 27, 2020 6:38 pm
There was a “Tanner Bros.” Ford dealer in Granite, OK, about 90 miles west of Chickasha. It looks like they were a garage for a few years, then picked up a Ford dealership in 1921 or 22:
