Magneto light questions
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Post by Jim Sims » Sun Mar 01, 2020 10:05 am
When was mag lights first used? When was the dimmer unit first used. When was the combination horn light switch first used ? Was the dimmer used with the push pull switch on the firewall?
Re: Magneto light questions
Post by Steve Jelf » Sun Mar 01, 2020 10:26 am
I can answer the first part of that. 1915 was the first year for electric lights. The only thing in the circuit besides the head lamps was the push-pull switch on the firewall. Somebody else will have to answer the rest.
Post by DanTreace » Sun Mar 01, 2020 10:31 am
The dimmer was used with the combo light/horn switch first 1918 model year, dimmer on dash. Later ignition /light switch on dash, the dimmer sat in place of the ammeter on magneto only T's up to 1927.
Older post with some factual info:
http://www.mtfca.com/discus/messages/11 ... 1292375409
