12V battery
Jon
First Name: jon
Last Name: ewing
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T touring
12V battery
Post by Jon » Sun Mar 01, 2020 3:07 pm
1916 Model T w/magneto only. I would like to install a small 12V battery (trailer emergency brake, burglar alarm system type) to operate LED headlights and an LED combination tail/brake lite mounted inside the kerosene tail lamp. I would like to tie this battery to the Battery side of the coil box for engine starting. Is there any issues with using the 12V system to start the engine, or should I make the entire system 6V?
Re: 12V battery
Post by Steve Jelf » Sun Mar 01, 2020 3:12 pm
The mag puts out a lot more than 12 volts when the car is running. It will be fine. Twelve volts won't bother your coils at all. They might even like it. :)
NHUSA
First Name: Fred
Last Name: Dimock
* REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Re: 12V battery
Post by NHUSA » Mon Mar 02, 2020 10:50 am
We used a 9 Volt lantern battery to help start our 19 T and ran it on the mag for many years.
When I decided to add LED stop lights I switched to a standard automotive 12 volt battery (put it in a box on the running board) and even had a plug so I can keep my cell phone charged.
As Jeff suggests I think the coils liked the 12 volt battery better than the 9 volt --
NH - Where I used to live - not the carburetor ! :lol:
Re: 12V battery
Post by Original Smith » Mon Mar 02, 2020 11:11 am
Hand crank T's like to start way better on 12v than 6v.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Re: 12V battery
Post by SurfCityGene » Mon Mar 02, 2020 1:09 pm
Larry, I keep my 12V battery charged up with my Mag using a diode and light bulb charger.
1912 Torpedo Roadster
Re: 12V battery
Post by Steve Jelf » Mon Mar 02, 2020 3:07 pm
I keep my 12V battery charged up with my Mag...
That's what I use in my 1915. Here's a page that tells how to do it:
http://dauntlessgeezer.com/DG102.html
dykker5502
First Name: Michael
Last Name: Deichmann
Re: 12V battery
Post by dykker5502 » Mon Mar 02, 2020 4:41 pm
Now the question was about 12 Volt and Steves setup is for 6 Volt and the lamp is for 6 Volt as well. Have anyone adapted this very simple setup for 12 Volt? The lamp need to be another, but have anyone found which?
Ford Model T 1914 Touring
Re: 12V battery
Post by Steve Jelf » Mon Mar 02, 2020 9:50 pm
Gene says he uses it for 12 volts. Maybe he can tell us if that takes a different bulb.
Re: 12V battery
Post by Scott_Conger » Mon Mar 02, 2020 10:04 pm
It isn't about the bulb (at least with respect to 6V vs 12V).
This will explain pretty much all of it: http://www.mtfca.com/discus/messages/41 ... 1416288062
