Nickel Plated Bolts
mytractor
First Name: Steven
Last Name: Smart
* REQUIRED* Type and Year of Model Ts owned: 27 Coupe
Nickel Plated Bolts
Post by mytractor » Mon Jan 07, 2019 12:04 pm
Hello:
Working on a 1927 Coupe and wondered if someone could tell besides the head bolts which bolts on the engine need to be nickel plated.
Thanks Steve
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Nickel Plated Bolts
Post by Humblej » Mon Jan 07, 2019 12:16 pm
The 2 bolts for the water outlet/fan bracket, and 2 bolts for the water inlet are dome shaped head nickle plated bolts like the head bolts.
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Mon Jan 07, 2019 12:54 pm
I believe the manifold clamp bolts are nickel plated on the Improved Ford as well.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Post by DanTreace » Mon Jan 07, 2019 5:25 pm
Walter T. Fishleigh's files in Acc. 94 at the Ford
Archives there is a memo dated July 26, 1926.
Nickel Plate used on:
Cylinder Head Cap Screws
Spark Plug caps and Thumb Nuts
Spark Plug Wire Terminals
Coil Box Terminal Bolts and Nuts
Water Connection Cap Screws
Manifold Cap Screws
Bright Zinc Plate used on:
Cut Out Cover
Moleskin Pyroxylin Used on:
Cylinder
Cylinder Head
Generator Bracket
Front Cover
Air Intake and Manifold
mytractor
First Name: Steven
Last Name: Smart
Post by mytractor » Mon Jan 07, 2019 6:20 pm
Thanks all for the information.
