ANOTHER WHAT IS IT?
Mark Chaffin
Last Name: Chaffin
ANOTHER WHAT IS IT?
Post by Mark Chaffin » Thu Mar 05, 2020 5:09 pm
Never seen one of these before. Anyone have any ideas?
Shane Lach
First Name: Shane
Last Name: Lach
Re: ANOTHER WHAT IS IT?
Post by Shane Lach » Thu Mar 05, 2020 5:17 pm
Could make a cool tachometer drive. Total guess though.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Mar 05, 2020 6:06 pm
It’s RARE, UNIQUE, Like finding HENS TEETH!
What else.., a Funky Monkey!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Mar 05, 2020 6:08 pm
Could be an air compressor drive.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Thu Mar 05, 2020 6:09 pm
I'm thinking maybe a mounting for an auxiliary magneto, but that's another pure guess.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Mar 05, 2020 7:09 pm
I like the Tachometer drive idea. It's available if anyone has an interest in it.
Larry Azevedo
Last Name: Azevedo
* REQUIRED* Type and Year of Model Ts owned: 12
Post by Larry Azevedo » Thu Mar 05, 2020 8:45 pm
I think it's possibly a drive for a governor. I think I may have one somewhere, I'll have to look.
Larry Azevedo
desertexplorer
First Name: Wallace
Last Name: Bellows
* REQUIRED* Type and Year of Model Ts owned: To Many!
Post by desertexplorer » Thu Mar 05, 2020 11:37 pm
It looks like it has a straight cut gear in the unit. How would that match up to the angle cut gear of the generator? Unless I’m missing something...
Post by Wayne Sheldon » Fri Mar 06, 2020 2:40 am
There is a missing idler gear. It probably had a larger helical cut gear to engage the generator gear, and an undersized straight cut gear for whatever it is that it drove. Notice that the straight gear inside is only about a half inch wide.
To eliminate the magneto drive idea, check inside that inner gear to see f it has the common universal magneto drive taper and key-way? If it has those, it was probably a magneto drive intended to keep the generator in operation with the magneto sitting on top of it. (I doubt that is what it was, however that was my first thought.) If that gear does not fit the armature of a common magneto? It would most likely be for something else (although something could have been changed?)?
It could have been a governor, or a tach drive? But on these, I would doubt it. Both those items have easier and simpler ways to accomplish the task. This is a bit heavier duty than those would need. I would be more inclined to think an oil pump. Maybe even a combination unit with distributor or even a water pump?
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Fri Mar 06, 2020 5:45 am
Maybe a supercharger? :lol:
Leo van Stirum, Netherlands
desertexplorer
First Name: Wallace
Last Name: Bellows
Post by desertexplorer » Fri Mar 06, 2020 11:11 am
Wayne nailed it, I didn’t think of the idler gear having both a straight cut gear and helical cut gear.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sat Mar 07, 2020 4:49 pm
I'm putting my money on the supercharger! :)
2nighthawks
First Name: Harold
Last Name: Schwendeman
Post by 2nighthawks » Sat Mar 07, 2020 7:47 pm
Well,....I'm guessing that because TT trucks were used for all kinds of things that involved pumping fluids, like water (fire fighting equipment) or fuel (as in tank truck) I'm thinking that the most common need for such a power take-off would be to drive a pump.
