Front floor board
Touring
First Name: Jim
Last Name: Poindexter
* REQUIRED* Type and Year of Model Ts owned: 1924 Ford Touring
Front floor board
Post by Touring » Fri Mar 06, 2020 11:46 pm
What is the easiest way to make your own front floor board.. 1924 Ford Touring. Thanks for the help
Re: Front floor board
Post by Steve Jelf » Fri Mar 06, 2020 11:54 pm
Borrow one and copy it.
sportbingo
First Name: Art
Last Name: Taylor
Post by sportbingo » Sat Mar 07, 2020 1:52 am
I first made a template out of cardboard. I shaped the cardboard using a band saw and drill hole. After, creating a pattern I used it to make my wood floor.
If you need more information contact me.
Art Taylor
Touring
First Name: Jim
Post by Touring » Sat Mar 07, 2020 7:24 am
Thanks for the imformation, my problem is my motor is in another state being rebuild. It won't be back till end of the year. I am trying to have the car finished when it get back. That why I can't make a pattern. I thought there might be a blue print out their. This is my first t project.
Touring
First Name: Jim
Post by Touring » Sat Mar 07, 2020 7:29 am
Last Name: Strange
Post by CudaMan » Sat Mar 07, 2020 8:35 am
jab35
Last Name: Bartsch
Post by jab35 » Sat Mar 07, 2020 3:46 pm
Jim: Here is a print of the bottom board, the one in front of the seat, from the Funprojects website. I suspect this one is the 'easiest' one to make. best, jb
http://www.funprojects.com/pdf/T1404B.pdf
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Sat Mar 07, 2020 6:46 pm
Art,where were you a couple years ago with that "tip'? :D I scratched my head bare trying to figure it out and finally just decided 1 day to lay some boards together,make it way to wide and trim it down.
sportbingo
First Name: Art
Last Name: Taylor
Post by sportbingo » Sat Mar 07, 2020 8:08 pm
My son and I glued the board together and trim the board using the pattern. Good luck Jim.
Art
Dan B
Last Name: Blaydon
Post by Dan B » Sat Mar 07, 2020 10:41 pm
The best way is to buy them from Jon Anderson. They are exact to the factory specs and fit perfect.
George Hand
Last Name: Hand
Post by George Hand » Sun Mar 08, 2020 9:25 pm
Jim, I would like to ask did you not have a floor boards when you acquired your car?
Something I have seen is a pre 1925 T that has had a 1926-7 pedals, transmission cover or even a complete engine assembly. The pre 1925 pedals can be bothersome because they are narrow. I am saying this because the pedal spacing on the 1926-7 is different and requires a custom floor board.
Post by Original Smith » Wed Mar 11, 2020 12:33 am
Getting them from Jon is the best idea. If not, find originals to copy, and be sure to rabbet the front and back sides. They were never varnished.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Mar 11, 2020 8:43 am
Don't expect dimensional lumber to fit. For my '26 Runabout I had to plane the boards to 9/16" to fit into the body's flanges and under the front board hold-down. The white panel in the photo is a piece of 1/4" hardboard that I used as a template for the upper board.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Wed Mar 11, 2020 9:28 am
Here's mine made from Poplar. So close they'd only fit this car. Your problem is no eng/trans in place. I'd definitely wait for it to be back in place. Anything else would be a crap shoot.
