Model A crank in a T engine. Question regarding timing.
BuckTspecial
First Name: tyrone
Last Name: thomas
* REQUIRED* Type and Year of Model Ts owned: speedster, racer, pie wagon, coupe
Post by BuckTspecial » Mon Feb 04, 2019 8:21 pm
Of those who installed an A crank into their T, how were you able to set the A crank to the T cam (gears) timing? Please list all timing changes you had to make. Thank you much.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Model A crank in a T engine. Question regarding timing.
Post by Kevin Pharis » Mon Feb 04, 2019 10:49 pm
The snout of the A crank must be machined down to the T dimensions and the T timing gear used. The timing gear keyway basically needs to be extended into the proper location, and the original remaining portion of the keyway filled and machined as it now makes up the front seal surface. No special timing considerations needed... assuming all machine work was done correctly
BuckTspecial
First Name: tyrone
Last Name: thomas
Post by BuckTspecial » Tue Feb 05, 2019 12:40 am
thank you Kevin but my question has more to do with putting the A crank gear (mark) inline with the T cam shaft gear (mark) for proper valve timing.
Post by RajoRacer » Tue Feb 05, 2019 12:55 am
Kevin is quite correct so you align the timing mark on the crank gear to the "0" on the cam gear - no different than timing a T set-up - the "A" fires the same 1243.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Feb 05, 2019 1:05 am
You appear to think that you use the A crank gear- you use a T crank gear, and as Kevin said above, you extend the existing crank gear keyway farther back on the crank nose after you shorten the front main journal . The centerline of the crank gear keyway is in line with the #1 and #4 rod journal and hence, inline with TDC on both a model A and model T, so nothing gets modified in the relationship of the gears to the existing keyway other than axial location.
BuckTspecial
First Name: tyrone
Last Name: thomas
Post by BuckTspecial » Tue Feb 05, 2019 12:13 pm
Very good. Thank you
