Does anyone know the steps needed to remove the trunk lid on a 1927 Model T Coupe.
Thanks for any and all help... Joe
joeg48@hotmail.com
1927 Model T coupe trunk lid
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: 1927 Model T coupe trunk lid
There is a hinge that bolts on to the top side edge of the deck lid on each end. You have to take one of them off, either side will do. The hinge is a plate with a protruding pin that fits into a hole in the body. Hinge bolts to the deck lid with 2 bolts. Might help to remove the bracket that holds the trunk open to allow you to lift the deck lid higher to find the hinges. Once you get one hinge off rotate the deck lid back to disengage the other hinge pin from the body.
JoeG48
Topic author - Posts: 57
- First Name: Joe
- Last Name: Gallagher
Thanks Jeff ...I was able to get the Deck lid off ..... Thanks again ... Joe
