NH Float valve
Topic author - Posts: 1532
- Last Name: Codman
NH Float valve
My NH 2-ball float valve is stuck closed. I have removed the carburetor and attempted without success to get the top ball to move freely. No luck. Does anyone have a recommendation for a good cleaning fluid that I can soak the valve in? I can buy a new valve - and I will if necessary, but I hate pitching the valve just because it has crud in it.
- Last Name: Hatch
Re: NH Float valve
Do your self a favor, get one of Scott Conger’s float valves. They work like an original. Dan
- Last Name: Saylor
Re: NH Float valve
The ball type float valves are notorious for sticking. Do as Dan says, get one of Scott's valves.
