wow i say WOW
RichardG
Topic author - Posts: 353
- Last Name: Grzegorowicz
- * REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
wow i say WOW
SHE WAS BACKED IN THE WAY BACK FOR THE SNOW'E DAYS LAST OCT, THIS MORNING I WENT UP TO THE SHOP AFTER SOME SMALL BRASS SCREWS TO MOUNT THE MORNING GLORY HORN---[ SPEAKER] ON MY EDISON, LOOKED OVER AT TRAFURTHA AND THOUGHT I SEE HER WIGGLE, IT WAS A NICE WARM DAY HERE IN VT, I WORKED MY WAY OVER TO JUST GIVE HER A TURN OR TWO JUST BECAUSE, WELL WHAT THE HEK' I TURNED THE GAS ON OPENED THE GAS VALE 2 1/2 TURNS, GAVE ER TIME TO FILL THE CARB, PULLED THE WIRE TURNED HER ENGINE THREE TURNS, PUSHED THE SPARK UP PULLED THE THROTTLE DOWN 1/2 WAY[SHE LIKES A LOT OF AIR AT FIRST,] TURNED ON THE SWITCH KEY GRABBED THE CRANK PULLED UP AND WHAT A SWEET SOUND IF THE MUD WAS DRIED WE WOULD HAVE TAKEN HER OUT, LIFE IS GOOD. STAY WELL YOU ALL.
Colin Mavins
- First Name: Colin
- Last Name: Mavins
Re: wow i say WOW
Wow Richard you have a way with words it's like I was there with you I think I will give my old girl a try Cheers Colin
