Spark Plug adapters
ModelTWoods
First Name: Terry
Last Name: Woods
Spark Plug adapters
Post by ModelTWoods » Mon Mar 16, 2020 11:46 pm
The spark plug adapters from 1/2" pipe thread to 14mm are available, but what it you have a head tapped for 14mm and want to use standard T 1/2" pipe thread plugs? I guess you're screwed. I'd like to add an explosion whistle, but I don't know of any adapters for 14mm plugs.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Re: Spark Plug adapters
Post by SurfCityGene » Tue Mar 17, 2020 2:37 am
You could just drill and tap to the pipe threads. A 1/2 - 14 tap would require a 23/32 drill.
1912 Torpedo Roadster
tmodeldriver
Last Name: Hester
* REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
Post by tmodeldriver » Tue Mar 17, 2020 9:20 am
Or get a different head.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Mar 17, 2020 10:57 am
If I knew there was enough metal around the 14 mm plug holes without causing problems, I'd drill and tap.
Post by Mark Gregush » Tue Mar 17, 2020 12:18 pm
A friend has a Z head with the 14mm plugs. He would like me to drill and tap for 1/2 plugs, but how much metal (aluminum) has been my concern as well. Chances are there is, but really don't want to mess it up.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Mar 17, 2020 12:25 pm
I would expect that if the head was originally sold with either spark plug option, there would be more than enough material to support the larger plug variety. I highly doubt there would be a separate pattern just to accommodate the relatively minor dimensional change between the 14mm and the 1/2” NPT plugs
