Interesting picture from 1912
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Tue Mar 17, 2020 4:59 pm
I found this book in dads stuff it was published by ford in 1962, for as long as I can remember we have been docked points at judging for the little clip that holds the horn tube at the bottom curve of the driver door . Well looking at the first car in the picture it sure looks like a little clip holding the horn tube . I guess when I paint the car that clip will stay. The picture of my car is when Dad brought it home June 1960
maybe this is a Canadian Thing Cheers Colin
Re: Interesting picture from 1912
Post by Wayne Sheldon » Tue Mar 17, 2020 5:37 pm
Interesting. The car appears to be a mid-year '12, and the horn's flexible tubing is definitely anchored near the bottom-back of the "door". The flexible tubing on the other cars are routed a bit differently. They mostly appear shorter, and pulled tighter to above the bottom of the "door". Although not visible, given how tightly they are pulled, I would guess they are also anchored there.
Also interesting (to me?) is that the second car over appears to have a painted black horn. Maybe could be lighting? However all the rest of the cars appear to have exposed brass horns.
Been a long time since i have seen a copy of that book.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Wed Mar 18, 2020 7:42 am
Anyone else surprised by the spare tires?
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Wed Mar 18, 2020 9:56 am
"Anyone else surprised by the spare tires?"
Do you mean the mounting location or the color, Jeff ? I didn't notice the color the first time I saw the pic, so thank you for sending me back for another look.
Do you suppose the spare is wrapped with a protective cover, or is it really a black tire ? I thought blacks didn't appear until sometime in the '20's.
Dick
First Name: Jeff
Last Name: Humble
Post by Humblej » Wed Mar 18, 2020 1:01 pm
Surprised there is a spare tire at all.
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Wed Mar 18, 2020 3:02 pm
In most cases Canadian cars don't have spares like that but I believe this is an order for a company so maybe special order . We have never carried a spare tire there is 3 tubes a jack and tire irons in the trunk . Since 1960 we have not had a flat ,I leaned how to change tires when we put new tires on in 2012 I will rotate them this year . Cheers Colin
