What Are these Parts?
DontKnowMuch
Last Name: Sanford
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Post by DontKnowMuch » Sun Mar 29, 2020 1:02 pm
These were with some speedometer parts but I don't know what they are. What are these parts?
Fire_chief
First Name: Charlie
Last Name: Gagel
Re: What Are these Parts?
Post by Fire_chief » Sun Mar 29, 2020 1:08 pm
The one on the left holds the windshield to the dash
Post by Rich Eagle » Sun Mar 29, 2020 2:28 pm
The one on the right could be a standoff for mounting a second spare tire. I found some for my Model A. It required 3 and replaced the lug nuts.
Does it have a threaded hole in the opposite end and the same size as the threaded stud?
Mine were simply made of hexagonal stock. Those are fancier.
DontKnowMuch
Last Name: Sanford
Post by DontKnowMuch » Sun Mar 29, 2020 9:37 pm
I will check tomorrow about the threaded shaft end. No, it does not have a hole in the opposite end.
I will compare the other part with my windshield supports on my 1914 touring. Thanks for the suggestion.
Post by Allan » Sun Mar 29, 2020 9:45 pm
James. to me the windshield brackets are for screens which mount straight up and down. The notches are set at the same height, and being brass, suit pre 1913 cars. For the 13-14 windscreens they were steel and one side was longer than the other to accommodate the slanting lower winscreen.
Hope this helps.
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Mon Mar 30, 2020 9:31 am
Looks the same as my 1912 windshield clamp
Post by Original Smith » Mon Mar 30, 2020 11:51 am
The right one looks like a limiting stop for a non Ford spindle.
