Got kicked off again.
Topic author - Posts: 979
- First Name: Stan
- Last Name: Howe
I've gone through this registration/can't log in/etc., etc thing about half a dozen time since the new forum format was activated.
Is anyone else having the problem?
I'll do the whole "new password" thing again and see if it works.
- First Name: Thomas
- Last Name: Hicks
- * REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
Re: Got kicked off again.
Well, yeah, since you are on, I guess it finally worked. I had a devil of a time getting on yesterday, but whatever the problem was has apparently been fixed.
I have a lot of problems with any "technology", and I think the forum change has been relatively smooth.
Please have patience, there are good men working on it...
- First Name: Tony
- Last Name: Bowker
I have had very few problems using this login pathway
https://www.modeltfordclubofamerica.com/phpBB3/
Use for your bookmark as well
Tony Bowker
La Mesa, California
La Mesa, California
- Last Name: Andreasen
- * REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Tony's got the right idea. That's how I finally solved all of my login problems.......just made it a bookmark. Thanks to our mods for that tip!
- Last Name: Doughty
- * REQUIRED* Type and Year of Model Ts owned: 17 roster, 17 touring, 22 coupe, 22 touring, 22 roadster pu, 24 TT cab
I was blocked using my Mac with Safari. Now use the Mac with Google Chrome and it works fine. Puzzling!
- First Name: Marv
- Last Name: Konrad
- * REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
- Board Member Since: 2010
-Stan-
Tony identified the link, and George ID'd the 'bookmark' of it. That is the route I've used, and it has worked every time. FYI, you might want to check-mark the "Remember Me" box if you're wanting to go back & forth between 'classifieds and/or discussion'.... FWIW - Not a bad idea either to log out when you're shutting things down. I also use FireFox 'Private Window' to help block a lot of ads.
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
- First Name: Jim
- Last Name: Eubanks
Even when I check remember me, I have to log in again every time I start the computer to be able to post. Something is not right because on all the other sites I get on, once you log in and check remember me, you do not have to log in again. Hopefully someone will fix this glitch.
- First Name: Marv
- Last Name: Konrad
-Jim-
Have you cleared your cache of cookies, or deleted the history?
- First Name: Dallas
- Last Name: Landers
I had to log in several times in the past couple days also. Last evening and today has been ok. Back to normal.
- Last Name: Hjortnaes
Jim I can login when I first get on. If I want to post something I have to login again. So I write my posting, hit submit, and login comes up. If I post again on another topic I have to login again. Strange.
- First Name: CHARLIE
- Last Name: BRANCA
I too have to log in whenever I leave & come back. Tried remember me & bookmarking while signed in. Nothing works. On android
(pad) or Win 10 (lap top). Also I've noticed a very marked increase in junk mail since working to get the new forum useable for me. I'm talking 1 or 2 a day up to (now) 15 or 20 daily. The only changes I've made are adapting to the new Forum. Brought it to Chris' attention.
- First Name: Jeff
- Last Name: Stevenson
- * REQUIRED* Type and Year of Model Ts owned: 1921 Touring
We’re working on it! Still no resolution, but I’m not giving up...Jim Eubanks wrote: ↑Thu Feb 07, 2019 5:21 pmEven when I check remember me, I have to log in again every time I start the computer to be able to post. Something is not right because on all the other sites I get on, once you log in and check remember me, you do not have to log in again. Hopefully someone will fix this glitch.
Jeff
Assistant WebSite Admin
1921 Model T Touring, 1930 Model A Roadster
Voltage Regulators, Starter & Generator Repair & Parts manufacturing
www.modeltregulators.com
www.modeltstarters.com
Its still not "remembering me". Hope you get it fixed soon.
Last bumped by Anonymous on Sun Mar 31, 2019 6:31 am.
