TT door latch
Rod Petrie
Topic author - Posts: 88
- First Name: Rod
- Last Name: Petrie
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
TT door latch
How do you take this latch apart or can it be done? I see they sell the internal parts (springs etc) but I can't figure out it comes apart. It looks like it is welded together.
Re: TT door latch
Rod, it does look spot welded together, two at the bottom and two single welds at other points. There are ways to break these. Some use flat ground drill on the dimples. There are special saws panel shops use for the same purpose. Once apart and new bits fitted, they are welded shut again.
Hope this helps.
Hope this helps.
