How do you remove brass steering case brass rivets?
TBones12
Last Name: Poane
* REQUIRED* Type and Year of Model Ts owned: 1916 Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
Post by TBones12 » Sat Apr 18, 2020 4:22 pm
How do you remove steering case brass rivets?
I drilled out the quadrant rivets but when I tried to bang out the brass case rivets they did not budge. And I am afraid of ruining it.
I want to replace the steel levers with brass levers.
Thank you for your help!
Art Ebeling
First Name: Art
Last Name: Ebeling
Re: How do you remove brass steering case brass rivets?
Post by Art Ebeling » Sat Apr 18, 2020 4:55 pm
There is a good article with pictures on Royce’s Model T Fix site. Art
Post by RajoRacer » Sat Apr 18, 2020 5:18 pm
I believe that the case pieces & rivets are all soldered together.
TBones12
Last Name: Poane
Post by TBones12 » Sat Apr 18, 2020 7:11 pm
Perfect, thanks!
