Bolt size question
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Bolt size question
Post by Belliott3 » Mon Apr 20, 2020 7:52 pm
What size bolt is used to hold the hogshead onto the engine pan? I think it's a 3/8-24 but not sure how long they are supposed to be - thanks!
Re: Bolt size question
Post by Allan » Mon Apr 20, 2020 9:09 pm
Bill, that is the size. There are three which go up onto threaded holes where the starter mount. These are shorter and are not drilled for a split pin.
Post by Original Smith » Tue Apr 21, 2020 10:13 am
A little common sense should do it! Some are 1 1/8" and some are 1 1/4". Just put the bolt in and see if it works!!!
