Tool Time
				StanHowe
- First Name: Stan
- Last Name: Howe
Re: Tool Time
Tire changing tool for split rims.
Re: Tool Time
Rim spreader. Google "MTFCA rim spreader".
https://www.google.com/search?client=fi ... m+spreader
Used to collapses/expand the 21" split rims (Ford in this case, other car makes may have used different size rims/wheels), so the tire could be removed or installed.
Re: Tool Time
Considering the few years split rims were used, I'm a bit surprised at how many spreaders are around. I bought one at an auction for $1. Nobody else knew what it was.
Re: Tool Time
When you consider that: A they are a tool and maybe were stored better and saved after the car/truck was gone.  B how many makes of cars used the split rims like Ford GM etc. The rim tool might have a better survival rate then the cars they were bought for. The one I have was made for larger split rims and will "just" work on the 21inch ones.
