Door Check Straps
Last Name: Juhl
Door Check Straps
Post by Oldav8tor » Tue Apr 28, 2020 5:35 pm
Would a 1917 Touring have had door check straps? If one is not careful it is easy to smack the doors on either the edge of the fenders (rear) or sidelamp (front).
DJPeterson
First Name: Dale
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1916 Roadster, 1925 Roadster PU, 1926 Canadian Fordor, 1927 Speedster
Re: Door Check Straps
Post by DJPeterson » Tue Apr 28, 2020 5:42 pm
Yes a 17 would have check straps with the footman loops as shown. Material as I recall would be from leftover upholstery scraps.
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Post by Jim Sims » Tue Apr 28, 2020 6:39 pm
My original 17 does not have footman loops. It has a very thick fabric strap. This is tacked behind the door cardboard and on the body it is fastened with 2 oval head screws thru a trim washer.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Apr 28, 2020 7:13 pm
The June 1917 Rip Van Winkle Ford has black cotton webbing that is nailed to the wood, under the respective panels.
My unrestored May 1917 touring has remnants of the door check cotton webbing under the panels.
R.V. Anderson makes and sells the appropriate door check material. My dad put a set on his July 1917 touring.
I believe he also is the supplier for Langs:
https://www.mtfca.com/phpBB3/posting.ph ... c87352174a
PS: if you want to "dress up" your car with leather door checks, you don't need to use footman loops. Instead, you fasten the leather strap over the panels and use nickel-plated oval head screws with nickel plated finishing washers, similar to what was done with 1913 and 1914 Fords.
https://www.modeltford.com/item/3876LSN.aspx
Post by Original Smith » Wed Apr 29, 2020 10:34 am
I used genuine U.S. Navy belt material on mine. It is exactly the same as Ford used.
Last Name: Juhl
Post by Oldav8tor » Wed Apr 29, 2020 8:33 pm
I didn't think of belt webbing..... Anyway, I ordered a set from RV. Anybody got photos showing the correct placement? Also, when installing them how much do you want them to hold the door off the fender / sidelight? I assume over time they'll stretch.
BTW - thanks for all the info. It helps :D
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Thu Apr 30, 2020 2:12 pm
Dale, that's interesting. Personally I have never seen door strap footman loops on a black era open car but they are pretty much universally used on closed cars. My '14 touring doesn't use footman loops but does use the fancy cupped finishing washers to hold the straps.
Post by Rich Eagle » Thu Apr 30, 2020 2:27 pm
This was the webbing on a rear door. I thought it might be about 1924 but don't know for sure. It was tacked and about that long.
