Lifter question
Modeltmike
Last Name: Sleep
* REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 27 touring and 26 Fordson.
Lifter question
Post by Modeltmike » Tue Apr 28, 2020 10:52 pm
I am helping a friend with a valve job. When we pull up the valves there is a “cap” over the lifter. It is small and can be removed. My cars all have adjustable lifters and I had not seen this before. Was this standard for the non adjustable lifters? Thanks Mike.
Last Name: van Ekeren
Re: Lifter question
Post by Kerry » Tue Apr 28, 2020 11:46 pm
No, not standard for the T engine, rotator caps would have been used in a rebuild some time later in it's life.
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Re: Lifter question
Post by Gene_French » Wed Apr 29, 2020 8:09 am
Mike:
also , there are shims that were used over the ends of the tappets to take up excess wear or to correct the clearance when too much material was removed from valve stem or tappet ( lifter) during a valve job … these stamped cups were usually in the .015 to .030 thickness … don't see these very often … always an optimist ..gene french
Modeltmike
Last Name: Sleep
Re: Lifter question
Post by Modeltmike » Wed Apr 29, 2020 8:15 am
Did they fit over a standard lifter, or is it a special lifter? I would assume the valve would have been shortened a little to get clearance? What was their purpose? Thanks Mike
Adam
First Name: Adam
Last Name: Doleshal
Re: Lifter question
Post by Adam » Wed Apr 29, 2020 10:04 am
It’s an accessory part that was put over the end of the tappet because the end is worn too deep. People used these shims when they did a valve job instead of replacing the tappets. If they aren’t worn thin, you can leave them in there. If you have the cam out, you should replace the tappets.
Green T
First Name: Thierry
Last Name: Michot
Re: Lifter question
Post by Green T » Sun Dec 06, 2020 4:27 am
The post is a bit old but,
Would you know if you can still buy those caps ? I would like to adjust valve lashes on the cheap ! ;) I plan to rebuild that motor later on.
Thanks in advance.
Randall strickland
First Name: Randall
Last Name: Strickland
Re: Lifter question
Post by Randall strickland » Sun Dec 06, 2020 8:30 am
Lash caps are used a lot in racing engines
https://www.summitracing.com/search/pro ... =part-type
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Lifter question
Post by Dan McEachern » Sun Dec 06, 2020 12:46 pm
Not sure you are going to find a lash cap made to go on a 7/16 diameter valve stem. But depending on how worn the end of your lifter is, you could always use a lash cap in the conventional manner and put it on the valve stem.
AndyClary
First Name: Andrew
Last Name: Clary
Re: Lifter question
Post by AndyClary » Sun Dec 06, 2020 1:22 pm
At 8 bucks a piece, new valves are not a deal breaker. The new valves are plenty long, If your lifter is too worn to adjust with a new valve, you need a lifter, again not very expensive.
Andy
Green T
First Name: Thierry
Last Name: Michot
Re: Lifter question
Post by Green T » Sun Dec 06, 2020 6:45 pm
Thank you all for the replies .
