1914 Roadster Rear Fender Bracket Bolts
John Haynes
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1910,1911,1912,1913.1914
Post by John Haynes » Fri May 08, 2020 5:58 pm
I am working on a 1914 Roadster and ready to install the rear fender brackets. The question I have is which way does the carriage bold get installed? Does the round head of the carriage bold show on the outside or does the square nuts show on the outside? I have not been able to find any photos of this area in any of the books I have. I would appreciate any help in this regard. Thank you!
Re: 1914 Roadster Rear Fender Bracket Bolts
Post by Rich Eagle » Fri May 08, 2020 8:36 pm
I don't see any answers to your query yet. If you have round holes in both the body brackets and the fender brackets I would question the use of carriage bolts. Later body brackets had square holes which would accommodate the carriage bolt head. Those cars would have the lock-washer and nut on the outside or fender bracket side. That is what I usually see. This discussion shows Steve Jelf's '15 with the bolts on the outside.
http://www.mtfca.com/discus/messages/59 ... 1478880586
This shows the nuts to the outside on a Rootlieb car.
http://www.mtfca.com/discus/messages/11 ... 1285274010
Hopefully, bringing this to the top will get some better response.
Best of Luck.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri May 08, 2020 9:37 pm
The nuts and lock washers are on the outside.
I have an unrestored 1917 roadster with a known history since new. The nuts are hex, not square.
Last Name: House
Post by George House » Sat May 09, 2020 7:42 am
Show your nuts on the outside ! And for ‘14, they’re square. The whole purpose of carriage bolts is for the square shoulders to bite into the wood. And for the ‘14 taillamp bracket, the nuts are also square....
John Haynes
Last Name: Haynes
Post by John Haynes » Sat May 09, 2020 9:38 am
Thank you Gentlemen for the information!
Best Regards,
John
Post by Original Smith » Sat May 09, 2020 11:24 am
I just checked my '13, which is very original, and it has square nuts. However, it had a couple of owners before me, so they could have been changed.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sat May 09, 2020 12:06 pm
All three bolts for attaching the roadster rear fender iron to the sill go through the body/frame bracket, then the wooden sill, sheet metal and finally the fender iron. The body/frame bracket has three square holes to accommodate the corresponding bolt shoulders.
In other words, the body/frame bracket, not the wood sill, prevents the bolts from rotating when you tighten the nuts.
