1927 Deck Lid
JoeG48
First Name: Joe
Last Name: Gallagher
1927 Deck Lid
Post by JoeG48 » Fri May 15, 2020 2:13 am
Does anyone know the trick to installing the deck lid on a 1927 Coupe.
I appreciate any help you can give me.
Thanks Joe (joeg48@hotmail.com)
Chris Barker
First Name: Chris
Last Name: Barker
Re: 1927 Deck Lid
Post by Chris Barker » Fri May 15, 2020 6:00 am
I recall it being tricky.
Have you tried starting from inside the car with the shelf removed?
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: 1927 Deck Lid
Post by Humblej » Fri May 15, 2020 7:15 am
Not hard to do but a bit tricky to reach by yourself. Remove the seat back and bottom cushion and put yourself halfway into the trunk to reach from there, while a second person holds the deck lid from the back of the car. As a teenager I did it myself from inside the trunk, but I wouldn't do it like that today. Install the hinge to the body on one side prior to installing the deck lid and place the other hinge on the deck lid. Hold the deck lid on an angle pointing one corner in first to engage the pre installed hinge. Slide the other corner with hinge into place, align the deck lid, then fasten that hinge to the body.
