ARE 26/27 ROADSTER DOOR LATCHES DIFFERENT
Bill Crosby
First Name: Bill
Last Name: Crosby
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Post by Bill Crosby » Sat May 16, 2020 12:09 pm
I am restoring a 1926 RPU and the latches that came with the car won't bolt up. Is there a difference between 26 and 27 door latches?
The one in the left In the picture Is what came with the 26 open car that I am restoring.
The one to the right Is from a 27 open customer car.
Witch one Is 26 or do I have the wrong Door Latches?
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Re: ARE 26/27 ROADSTER DOOR LATCHES DIFFERENT
Post by Jim Sims » Sat May 16, 2020 12:20 pm
The one on the left is for 1925 or earlier.
TMiller6
First Name: Thomas
Last Name: Miller
Board Member Since: 2006
Post by TMiller6 » Sat May 16, 2020 1:18 pm
The on on the left looks like what’s on my 26.
The one on the right is for a 1928 Model A and was used prior to the introduction of outside handles.
Tom Miller
Post by DanTreace » Sat May 16, 2020 2:08 pm
There is subtle differences in the '26 and the later '27.
Here is the '27 version, easy to spot with the clipped top corner. This one has hole for the upholstery nail socket, for the trim board on the door and the latch tucks into the door panel opening.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sat May 16, 2020 5:51 pm
Dan, maybe you explained this in another thread and I missed it. Why is that man in your avatar peeing on his model T? :D
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Sat May 16, 2020 9:50 pm
Thank you all for your help.
Post by Original Smith » Mon May 18, 2020 10:51 am
As far as I know, the 1925 and 1926 door latches are the same.
