Bauer Steering Wheel Lock Key
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Feb 10, 2019 6:06 pm
What are the likely possibilities of ever finding a key for a Bauer Steering Wheel Lock?
I know the lock was made by Briggs and Stratton and has an E 37 Key Code showing.
That is all the information I have available.
Bauer Lock.JPG (39.51 KiB) Viewed 3045 times
TFan
First Name: Jim
Last Name: Riedy
Re: Bauer Steering Wheel Lock Key
Post by TFan » Sun Feb 10, 2019 11:09 pm
Jim, I have a steering wheel locking device I don't recall the brand but the lock is a Russwin. I took it into our local locksmith I believe he is second or third generation at the shop. He was able to look up the numbers in some catalog NO computer and was able to modify a present day Master brand key to fit. I think it cost me like seven dollars. Jim
Post by DanTreace » Mon Feb 11, 2019 9:29 pm
Quick Google search found this E 37 key code...might help? A good locksmith can do wonders as posted by Jim.
https://lostakey.net/m-series-key-code- ... sco-p-1364
Found it on page 2 of the listing as the keys aren't in numerical order.....E-37 Replacement key for EAGLE and KNAPE VOGT ONLY
This key code series is intended ONLY for Eagle and KNAPE VOGT products and is a very old code. The original 4 wafer key blank is no longer available so we use the equivalent...
$8.99
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Tue Feb 12, 2019 7:26 am
I had a key made for a steering wheel lock made at a local locksmith shop a couple of years ago. I did have an original key, but he didn't have a blank for it. He did some searching and found another blank that worked. This shop has been in business for years here. Just a thought. Dave
1925 mostly original coupe.
