excessive play/ slop at the u-joint
bobt
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1915 touring 1926 roadster
Post by bobt » Sun May 24, 2020 6:39 pm
I've been working on oil leaks on my 1915 touring. Today I drove around with the floorboards off and noticed excessive movement at the u-joint connection (I call it a ball and socket) do I need to add the aftermarket shim? Can I adjust the radius rods to help this? Thanks, bobt
Re: excessive play/ slop at the u-joint
Post by RajoRacer » Sun May 24, 2020 7:12 pm
Install a shim - the torque tube ball has excessive wear.
bobt
Last Name: Thompson
Post by bobt » Sun May 24, 2020 7:34 pm
No gasket. Correct? bobt
Post by Jerry VanOoteghem » Sun May 24, 2020 7:44 pm
No gasket between the retaining ring and the ball, but there is a gasket between the 4th main and the hogshead.
Yup, you can put a shim between the ring and the ball. Be sure it doesn't bind when you're done.
