Where does this brace go
bnchief
Topic author - Posts: 191
- First Name: Steven
- Last Name: White
The top two brackets are fender brackets the top is front fender on 27 fordor the second is the rear fender bracket I have no clue what the third bracket is could it have been a brace for the 26-27 fuel tank i cannot figure out where it came from does not match up with fenders or anything else.
bnchief
- Last Name: White
Re: Where does this brace go
Wll i am clueless as to how to post a picture here it came up in the preview
Try refreshing your screen. I can see them.
bnchief
- Last Name: White
Thanks Mark i finally got it to go it is a little confusing to get it to work
bnchief
- Last Name: White
Just curious. Are you sure it isn't a somewhat deformed front fender bracket? I am not an "improved" Ford expert, but I do know that Ford changed the brackets and headlamp mounting to at least four variations which may explain the difference in the holes not being the same. The one bracket (lower in your picture) appears to have been bent down badly, with a significant change in the arc, and buckling on both ends. I cannot tell from the photo if the overall length would match or not.
bnchief
- Last Name: White
Wayne that is what I do not know each end of that brace has two small holes and it is kind o vee-ed at the end where the bolts are the other two brackets match up to the body at the and frame at the front and match up with the holes in the fender and it could be an brace that does not even go with this car as there is only one of them.
