Carb for a fronty head. What
Rjackson
First Name: Ron
Last Name: Jackson
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
Board Member Since: 2014
Post by Rjackson » Mon Jun 01, 2020 1:42 pm
I am looking for a carburetor to be used on my fronty head. I have tried all kinds but still have not found one that is right
Re: Carb for a fronty head. What
Post by RajoRacer » Mon Jun 01, 2020 1:54 pm
Walt B. - what are you running ???
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Jun 01, 2020 1:59 pm
Zenith HP4A is really nice for a mild one. HP5A for a massaged one. IMHO. Straight up bolt on with a stock stub manifold.
jmemjr
Last Name: Memmelaar
* REQUIRED* Type and Year of Model Ts owned: 1912, 1914, 1915
Post by jmemjr » Mon Jun 01, 2020 4:57 pm
I tried Solex and BB-1 and I am a fan of the BB1. Easier to adjust and I like the updraft, it reacts better when giving throttle to it. As for a period correct one, I will defer to others.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Mon Jun 01, 2020 5:48 pm
I've used a Zenith HP5A and liked it for general performance as well as being correct. The only challenge is jets are fixed and not readily available. Stan Howe has some solutions for that.
Late last summer I tried a Weber 32/34 downdraft. Friend had been using one on his Prus head speedster and it's great. Required making a manifold of course for the Fronty but pretty straight forward. I did a test run between the Zenith and Weber and found a significant performance improvement. My run was up a 10% grade and from dead stop to where I had to slow for a light, I got to 54 with the Zenith and 58 with the Weber. My car isn't correct anyway so I went ahead and sold the Zenith.
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Fri Jun 05, 2020 2:38 am
Zenith was a "set and forget" carburetor that controlled everything through jetting. That was fine when Zenith had dealers with all the jets in stock, now we live with what we got or carefully try to modify the jets. Stan Howe makes an adjustable main jet for his restored Zeniths. It looks pretty cool.
In Stromberg carburetors, an LB-1, MB-1, OC-2, or OS-1 should mate to the head. I believe the late Ralph Ricks had an MB-1 and liked it. I personally like the design of the O series, and the OS is similar to the OF that we all know, but it has a different economizer needle. Stromberg actually sold the OS-2 in a kit for Fronty according Stromberg's 1926 dealer's manual. Stromberg has idle and high speed adjustments, so the Zenith jetting issues are alleviated.
Hope that helps!
