Help me identify this
SamInStL
First Name: Sam
Last Name: Atkinson
* REQUIRED* Type and Year of Model Ts owned: '27 Runabout, '25 Panel Truck
Post by SamInStL » Wed Jun 03, 2020 11:07 am
This hubcap has me puzzled. Pre-T probably. First 1500 maybe. Can anyone help me identify this?
Re: Help me identify this
Post by Mark Gregush » Wed Jun 03, 2020 11:30 am
It is later truck after the Model T era. Exact years not sure, without looking in the Green Book. (The Green book is the Ford chassis parts book that covers parts from 1928 up to 1948)
Post by Rich Eagle » Wed Jun 03, 2020 11:32 am
I believe it may be a front hub dust cap that fits from 1936-1948.
http://www.earlyfordstore.com/product_i ... 445f6a1e1e
Dropacent
Last Name: Morsher
Post by Dropacent » Wed Jun 03, 2020 2:11 pm
Sam, they got it for you. From my poor memory, I believe 1904 was the first year that FoMoCo put their name on a hubcap, and that was on the 4 cylinder model B. They were assemblers, and not manufacturers so they did buy a catalog item in the basic hubcap and applied this medallion. It was quite a while until they came up with the famous Ford script. This particular one is off serial #1 B
Post by Wayne Sheldon » Thu Jun 04, 2020 2:52 am
Even the 1909 model T had a block letter "FORD" hubcap. The "Ford" script was on most, but not all 1909 model Ts on the radiator, as well as on the early number plates attached to the seat riser or dash. Significant use of the script does not go much earlier on any part of the Ford automobiles.
I have no specific knowledge of the cap you show, other than I have seen similar steel with script dust covers on several '30s into the '60s Ford cars and trucks. Some had internal threads, others had external threads.
John Warren
Last Name: Warren
Post by John Warren » Thu Jun 04, 2020 9:06 am
Radiator cap?
SamInStL
First Name: Sam
Last Name: Atkinson
Post by SamInStL » Fri Jun 05, 2020 1:03 pm
The octagonal shape and Ford script sure looked like a hub cap and the external threads made me think pre-T. I hadn't considered the fact that script wasn't used right away on T's. Maybe it is from a truck in the 30's but for now it will be a wall hanger in my garage.
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Jun 05, 2020 3:24 pm
It is a neat item, Sam. Display proudly. The earliest use I’m aware of the famous Ford script was the name plate on the 1905 model F ford. It was enlarged a bit to include space for the serial number on the big brother of the T, the 1906 model N,R,S. If anyone has an earlier recollection it would be nice to share here. This is the model F plate, right below the front seat on the wood body.
. Photo from Mr. Williamson’s F, later owner by Grooter,Gould, and now Heyen.
Post by Mark Gregush » Fri Jun 05, 2020 8:05 pm
It is as Richard said, truck front cap.
Post by TRDxB2 » Fri Jun 05, 2020 11:59 pm
I have these which are similar in shape and one has a bit of a smear of dried grease around its threads. But they are smaller and no Ford script. Was told they were grease caps for a Model A - never said year. So these are what you don't have
Post by TRDxB2 » Sat Jun 06, 2020 12:37 am
Was about to quit looking and found this
SamInStL
First Name: Sam
Last Name: Atkinson
Post by SamInStL » Sat Jun 06, 2020 7:58 am
Frank I'm glad you kept looking. I believe that's exactly what I have, a hub cap for an AA. Even though it's now identified I'll still use it as a wall hanger in my garage. Thanks to all for their input.
