What have you done in June 2020
Jim_PTC_GA
Last Name: Fisher
* REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Post by Jim_PTC_GA » Thu Jun 04, 2020 9:12 am
I was hoping someone would start one of these because I've done some things. Didn't see one so I'll begin.
I finnaly finished the front bumper on my Delivery/ Hack. The mounts are the rear mounts from a 1930s A with a tiny bit of modification and the bumper is from a 30s A also.
I also finished the Chalkboard side panels for the car. These slip in and lock and easily come out depending if you want to drive a delivery or open it up for passengers as a Hack. The Chalkboard will make it easy to change the logo or sign depending on the mood of the day.
Just give me time to Rust and I'll be good as new. :) Wabi-Sabi
Re: What have you done in June 2020
Post by DanTreace » Fri Jun 05, 2020 9:34 am
While the motor is out, took apart the front end for rebuild.
The front spring was a put together of some straight cut leafs, and was worn. So replaced it with a fresh rebuild, leafs sanded down, primed, coated with graphite paint, and then covered with nice black. The axle was in rather poor shape too, one perch fell out, both yokes were well worn at the upper hole, and one side had stripped threads. The wishbone sported a very 'egg' look at the ball, never saw one that worn, like a tear drop egg! In fact, two shims fell out from the crankcase socket! Was too worn to shim, should never have been used to begin with. That piece is being replaced too.
Now all the parts are inspected, fixed, painted and ready to go back in place. ;). Another axle that was ready to go, another tie rod, and new tie rod bolts, drag link was salvaged and ok, and another wishbone with solid very round ball of right diameter.
John Codman
Last Name: Codman
Post by John Codman » Sun Jun 07, 2020 11:07 am
Replaced the dashboard wiring harness in my '27. A couple of the wires were deteriorating and although I am insured, I would hate to lose my T to a fire.
Last Name: Strange
Post by CudaMan » Sun Jun 07, 2020 4:55 pm
John, if you haven't already, you can install a fuse in the location shown in the diagram to protect everything downstream from the starting switch (except for the starter and starting wire itself):
Post by Steve Jelf » Tue Jun 09, 2020 12:50 am
I never posted any T work in May because I didn't do much. Busy with other stuff. Now I'm back in the game, fixing Lizzie's broken windshield. I replaced the broken upright with a piece cut from a junk frame. Did a couple of manifolds while I was at it.
Blasting in the cool of the morning.
Uh-oh... That's not good.
Digging out the crack for filling.
Crack filled.
Post by Steve Jelf » Tue Jun 09, 2020 12:55 am
Earlier I repaired these rounded-out carriage bolt holes, and today's job was to fill the little craters around them.
Slathering on the flux.
Melting on the body solder.
Spreading it around, trying not to burn up my stick.
Nobody will ever accuse me of being a skilled body man. I'm calling this good enough for gummint work. :)
Post by Rich Eagle » Fri Jun 12, 2020 7:13 pm
These 3 photos are looking up at my rain-rails at the front of my Coupe top. When I made these rails I made them straight and bent them on the car. I knew the pine would cause problems and here the nails have pulled out as the wood gets old (7 years). Today I mixed up some West System Epoxy that is a dozen or more years old. The 2 fluids still pour out even at 10% left each. I dobbed the epoxy in and pulled both sides in using a furniture clamp. I will let it sit overnight and see how well it worked.
I had enough epoxy left to re-glue two moldings back in place. The one shown and one above the quarter window. These had been glued with Elmer's and no nails. Not bad for 7 years I suppose. As with the rest of this car I am experimenting with different things that may not be the best choices but I'm learning a lot from it.
Post by DanTreace » Fri Jun 12, 2020 9:18 pm
Some clean bench time, rare thing in the garage, usually doing some greasy, gritty stuff.
So received the plastic rebuild kit for the '25 coil box, and new brass screws, nuts, and porcelains, along with new bronze contacts.
The old box had been restored in the past reusing contact and porcelains, and with heavily varnished plywood that was about splitting apart.
Now the box is good for at least another 50 years. :)
Every contact and brass screw got soldered together for best electrical connections.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sat Jun 13, 2020 7:03 pm
Well after 2 1/2 days without power after the storm, it was time to clean up some damage.
Who says work cant have fun mixed in.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Sat Jun 13, 2020 7:22 pm
You back on the grid now buddy ?
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sat Jun 13, 2020 7:48 pm
Yup. Just livin the Amish life for a couple days. Country boy can survive !
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Sat Jun 13, 2020 11:44 pm
Dan, I like your coil box rebuild. I recently bought the parts from Lang’s to do the same rebuild.
Darin
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Sat Jun 13, 2020 11:52 pm
Wrapped up over a month of concentrated effort to get the 13T running, again. Over the last week-ish I made a new gas line, cleaned the carb, set the timing on a new anderson anco flapper style timer, and got the old girl running for the first time in years. (Well for a few moments before I had to stop it so the engine didn’t overheat due to no radiator. Have one on order with Brassworks)
Darin
Squirrel
First Name: Jim
Last Name: Forbes
Post by Squirrel » Sun Jun 14, 2020 1:18 am
Took the coupe apart enough that I'm going to sandblast the frame tomorrow...
the fun part will be getting the car all back together and driving while it's still June 2020. I think I can make it.
jachady
Last Name: Chady
* REQUIRED* Type and Year of Model Ts owned: 1924 Fordor
Post by jachady » Sun Jun 14, 2020 8:27 am
Putting in a complete exhaust system.
Post by Rich Eagle » Sun Jun 14, 2020 4:52 pm
The repairs to the rain-rails reported Friday seemed to work. I installed some long screws to help hold them tight against the roof structure. Some thin paint followed by rusty waster hides the shine.
As it turns out some of the new aluminum moldings are working away from the body. My solution was to force them back in place using a 2x4 against the wall and then against a heavier chassis. Then drill and countersink for a wood screw and grind the head flush.
I though some might enjoy the improvised board where a C-clamp won't work. :D
TTFarm
Last Name: Barker
* REQUIRED* Type and Year of Model Ts owned: 1926 TT
Post by TTFarm » Sun Jun 14, 2020 5:20 pm
Lots of thumbs up from family members with this one. After sitting on bare springs, boards, foam, bare gas tank etc, we ride with some comfort.
kelly mt
Last Name: Kelly
Post by kelly mt » Sun Jun 14, 2020 10:00 pm
My starter quit working so I pulled it and found the lug solder connection had broken. So I repaired it and decided to check my three shelf starters. Two of the three had the same problem. It turned out to be a starter fest with help from Shop Cat #3.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Mon Jun 15, 2020 12:45 am
Nearly finished the rebuild of a 1912 magneto coilring.
I will post a few photos of the job in the next 3 posts.
Her are the first.
Andre
Belgium
AndreFordT
First Name: Andre
Post by AndreFordT » Mon Jun 15, 2020 12:47 am
second
Andre
Belgium
AndreFordT
First Name: Andre
Post by AndreFordT » Mon Jun 15, 2020 12:52 am
Last post.
I need to build a new contact point and coat the coilring.
Andre
Belgium
RalphS
First Name: Ralph
Last Name: Sullender
* REQUIRED* Type and Year of Model Ts owned: 21 tt
Post by RalphS » Mon Jun 15, 2020 6:05 pm
Drove in 2020 NORTH PLATTE HIGH SCHOOL GRADUATES PARADE .
PAUL
PAUL
Grandson Paul
21 tt
21 tt
thumbnail (6).jpg (141.06 KiB) Viewed 20508 times
Around and around we go and where we stop we check the gas oil water and tires.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Tue Jun 16, 2020 8:27 am
I took a quick bath in LA’s Totally Awesome Cleaner. That’s the end of this story. It started when I removed the inspection cover to adjust connecting rods. It was the first time I’ve done that and wasn’t prepared for the ensuing mess. I made a jig for my floor jack like the one many of you have seen Steve Jelf use to remove a rear end assembly. I raised my front axle until the tires were about a foot off the ground to drain the oil out of the dips. I let it drain for a day. While maneuvering the cover around the various rods underneath, it tipped and poured a substantial amount of oil onto my face, hair, shoulder, etc. My creeper had an oil slick on it.
After said LA bath, the connecting rods looked decent and number 2 rod and cap were recent replacements. Number 3 needed to be taken up, which was the source of audible rod knock. Strangely, the shims were solid brass and mic’d at .033”. They were not laminated. I sanded them on a surface plate to .029” to get a proper fit. I’m waiting for a replacement rod nut since one on number 3 stripped. I also ordered a new set of proper shims to replace the solid ones I have now.
EricMac
First Name: Eric
Last Name: Macleod
Post by EricMac » Tue Jun 16, 2020 6:24 pm
How about finishing up a 25 year restoration? Mark and Phil Eyre's '11 Torpedo is done. Looks like a decent job to me...
Seriously folks, the car is absolutely stunning.
11 Torpedo done
11 Torpedo done
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor
1926 Depot Hack project
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Wed Jun 17, 2020 6:17 am
Mark, I have seen many posts where the front of the car was raised a foot or so to drain the oil. That doesn't work, think about it. In order to drain the dips in the pan inspection cover, it would have to be near vertical to get much of the oil out. Raising the front a foot would only drain a very small amount of oil out of the dips. Take a pan inspection cover and fill it with water and tip it up a foot on a board or something that is the same length as the wheelbase of a T. It ain't going to drain much more. JMHO Dave
1925 mostly original coupe.
Jim_PTC_GA
Last Name: Fisher
Post by Jim_PTC_GA » Wed Jun 17, 2020 9:50 am
For the first time I pulled out my Delivery/ Hack out of the garage. I needed to spin it around and put in the shop the other way in preparation to lift the body to remove the fenders and splash shields. It took 7 months to build the body and the whole time I kept worrying that it would be to tall. It clears the door by 1 inch. No problem. :) I wanted to finish all the body movement before putting in the Windows.
Last Name: Hjortnaes
Post by DHort » Wed Jun 17, 2020 12:07 pm
Remember, you can always let the air out of the tires,or at least some of it, so it fits a little better under the door. Then air them up and go for a ride.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Jun 17, 2020 1:57 pm
Jim, with only 1" clearance I would suggest wedging a board between the ground and the open garage door to make sure that it is open as far as it can be and stays that way. You put too much into your truck to risk damage.
Last Name: Strange
Post by CudaMan » Wed Jun 17, 2020 4:01 pm
Most garage door openers have up and down stop adjustments on the control unit. Adjust the up stop so that the bottom of the door rises up enough so that you have use of the entire height of the garage opening. :)
paddy1998
Last Name: Delaney
Post by paddy1998 » Wed Jun 17, 2020 9:57 pm
Hmmm, what have I done in June 2020?
Well, I chased down a miss in cylinder 3. Having ruled out fuel and spark I decided that a valve job was in order. When removing the head the center bolt under the firewall became rounded off for some reason and would not budge at all.
After a week of fooling around, it became apparent that the bolt is seized in the head, not the block, and will have to be turned out by spinning the entire head.
Therefore I have to pull the engine. While I'm in there I'm going to inspect the clutch spring, and clutch disks and replace as needed.
Also thinking of switching to kevlar or wood bands and now would be a convenient time to do that.
And maybe a couple of internal accessory oil lines.
And maybe powerwash and paint the hogshead. And the crankcase. And the head.
I'm sure I'll think of something else . . . :lol:
Post by Scott_Conger » Wed Jun 17, 2020 10:06 pm
The head ain't gonna spin unless the valves are sunk hopelessly into the block, and I doubt that
Soak it with penetrating oil and then weld a nut onto it or otherwise hit it with some super heat, fast. If that doesn't do it, pull the firewall and drill it
paddy1998
Last Name: Delaney
Post by paddy1998 » Wed Jun 17, 2020 10:17 pm
It spins.
I can turn it enough to expose all of cylinders 1 & 2 and about half of cylinder 3. The only thing that stops it is that the head hits the firewall.
It seems pretty clear that the bolt seized in the head and was never tightened snug into the block, but I'll find out for sure when I get the engine out.
Post by Mark Gregush » Thu Jun 18, 2020 12:12 am
Off topic! LOL I spent the day getting the 1920 Dodge running. :D After doing some moving around and taking down a fence I moved the 25 into the back yard. Between bring over the extra Dodge parts and very soon the car, I have a T rear end to build. Can you spot the Ford parts, no not the Hasslers.
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Thu Jun 18, 2020 9:14 am
Mark:
you will really like the Dodge Brothers touring … I have had 7 DB cars over the past 35 years , currently have a 1925 touring … powerful and reliable cars … also , the Dodge brothers club offers much technical support as does the MTFCA … if I can help with questions please do feel free to ask ...always an optimist...Gene French
John Codman
Last Name: Codman
Post by John Codman » Thu Jun 18, 2020 11:56 am
Thanks for the fuse tip, Cudaman.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Thu Jun 18, 2020 10:05 pm
I took my bride to the new house Im finishing up about 5 miles from home.Then we took the the 25 or 30 mile long way home. Weather is 75 and sunny. Around a couple lakes and miles of country road at 20 mph and the old pickup got us home just as the sun was setting. What a great way to end the day.
Post by Mark Gregush » Thu Jun 18, 2020 11:28 pm
Mark:
Thanks Gene. :)
TMiller6
First Name: Thomas
Last Name: Miller
Board Member Since: 2006
Post by TMiller6 » Fri Jun 19, 2020 2:34 pm
I Installed the wiring harnesses on my '26 Roadster. Engine runs but no generator or magneto. After I scrub up I will polarize the generator and inspect the magneto post.
I also made a mental note to give this car to my grandson when the battery needs to be replaced. While contorting and hooking up the battery cables on the maintenance free battery I realized some high school kid at the gas station was probably stuck with the cruddy job of removing three caps and adding water.
Tom Miller
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Fri Jun 19, 2020 3:56 pm
Changed the oil and adjusted the low and brake bands, lubed everything, and checked the tire pressure.
Adjusted my OF once more and I really think I found the sweet spot.
Went to get some gas yesterday, as soon as I back out of the garage and turn around, it started pouring !!
Maybe today.... :)
Post by DanTreace » Fri Jun 19, 2020 6:05 pm
Rebuilt the rear spring on the '25 Coupe, 8 leaf.
Used 6" grinding pad, cleaned off rust, and rounded the contact edges of the leaf ends for good sliding.
Now a coat of primer, that keeps rust stopped.
Let that fast dry, then coated the contact surfaces with graphite paint.
All-threaded rod and pulled the stack together, then held it fast with large C-clamps.
Lastly, pulled the all-rod, and placed the proper spring bolt and nut.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Fri Jun 19, 2020 8:31 pm
I spent most of yesterday under my 20 roadster taking up the rods. I haven't adjusted them since 2008. They all needed .003 from each side of each rod cap. (1 shim of the stack). She's noticeably quieter! While under there, I remembered a tip that Mark might use. Chevy 350 rod bolts work well but you need to remove the knurling by the bolt head for them to seat. this is easily done by chucking the bolt in a drill and use a flat file to file them smooth. Self locking rod nuts are then torqued on. I had done this years ago and saw the mixture of old cotter pinned nuts and the locking ones. I torqued them all to 35 ft/lbs but the modern bolts can take 40 ft/lbs easily. Took her for a spin to WallyWorld to get a motorcycle battery.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sat Jun 20, 2020 8:33 am
Drove the TT to beakfast
Nathan Pederson
First Name: Nathan
Last Name: Pederson
Post by Nathan Pederson » Sun Jun 21, 2020 9:53 am
Dallas, The TT is a beaut and looks like you're putting 'er to good use! Nate
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Jun 21, 2020 6:13 pm
Thanks Nate. Its pretty dirty from living in the barn but I think its at home there. Its a real joy to drive.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Jun 21, 2020 6:27 pm
I just wish Dallas would paint those rear fenders! Just looks tacky man! Are you from Tin-A-See?
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Jun 21, 2020 6:30 pm
Hank, T's are never really finished are they. :D
Post by Scott_Conger » Sun Jun 21, 2020 6:54 pm
Finishing up another one. Clean, but not gussied up yet for it's photo
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Thu Jun 25, 2020 9:53 am
I have my engine and trans sorted out and even drove down the lane and back. Currently I am working on the top bows. The bent wood bows need shaped to fit inside the metal bows and be cut to the length needed for the correct overall shape. Here is a picture of the bows wired together at the correct hieght and shape with the exception of the front bow that needs to be shorter to be closer to the windshield. Art
Post by Steve Jelf » Sat Jun 27, 2020 12:17 am
I've spent most of June on other chores, but just did this bit of Model T work. The patient for this treatment was the pan from my 1923 touring.
Before doing the actual job I had to adjust a frame to the correct 211/2".
There were two problems with the pan arms. 1 The holes didn't line up with the frame holes.
2 The ends angled up off the frame rails so much that I had to raise the front of the body to get the engine out of the car.
It would be pretty tough getting a bolt through that.
Apply pressure with clamps and heat to orange.
Post by Steve Jelf » Sat Jun 27, 2020 12:19 am
Heat to orange, line up holes, let it cool.
Sitting much flatter, hole lined up.
Ditto on this one.
Jim_PTC_GA
Last Name: Fisher
Post by Jim_PTC_GA » Sat Jun 27, 2020 3:03 pm
June has been a good month to get allot done. I have jacked up the body, removed and painted the fenders then reinstalled. Painting betwen storms was a bit tricky but i managed it. I have also come to think I will paint a chalkboard on all my vehicles, it makes it easy to keep track of what need to be done so I don't forget.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Jun 28, 2020 10:38 am
I gave the TT a bath to get rid of the bird bombs and barn dust.
Also adjusted reverse and brake bands in the pickup, opened up the holes in screen to 7/16. Complete lube job.
They are ready for the open road.
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Sun Jun 28, 2020 12:57 pm
When I finished restoring our 15 runabout in April, the one thing that I wasn't happy with was the anemic chirp that came the reproduction reed. Well yesterday the local Flatland T's club had a workday at Gary Paulsen's place to work on an upcoming T display at the local museum. I mentioned my horn reed situation to Gary, who shortly afterward brought me a box of vintage reeds for me to find a better one.
After I got home I swapped out the reed and wow, what a difference. It now sounds like I have a large Canada goose trapped under the hood! I didn't know how nice and loud that horn should really sound. It is great that we have people in the T community who are willing to share their knowledge or parts on occasion with a fellow T owner.
For those that don't have a bulb horn on their T's, the reed goes in the straight tube just below the bulb. Also shown in the picture is an aftermarket steering column brace that I added. Our 21 touring has one, and before I added this to the 15, you could tell a difference in how solid the column feels. Like a transmission screen and outside oil line, I think that this is one of those aftermarket items that's worth having.
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Sun Jun 28, 2020 10:37 pm
Reinstalled front and rear axles along with wheels and tires. All rebuilt. A huge thank you to Andy Loso! He did all of the rebuilding.
Wheels are from Stutzman's. I'm only the reinstallerr!
Post by Steve Jelf » Sun Jun 28, 2020 11:46 pm
Michael, what is it? The car looks like 1915, but the front plate is 1916.
Post by DHort » Mon Jun 29, 2020 12:24 am
Michael
Remember for a long time that the Ford Motor Company was just an assembler. Dodge Bros and others made their parts for them. Consider yourself and early Ford guy.
Michael Peternell
First Name: Michael
Post by Michael Peternell » Mon Jun 29, 2020 6:15 am
Good eye Mr Jelf! You are correct. I just haven't got around to fixing that. I'm hoping I can trade my '16 plate for a '15.
Virtus
First Name: Paul
Last Name: Robertson
* REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
Post by Virtus » Mon Jun 29, 2020 4:43 pm
Being a new owner I look forward to driving my Manchester built 1921 TT with some trepidation! Today was no exception. I have owned the truck since October 2019 and have only driven it 3 times.
Covid19 "lockdown " has been spent changing the colour from a garish red and white to a more sombre green but, the wheels remain red. There have been many other jobs to do as old vehicles often have. Today however was a special day. I have found out that it was registered to use on the highway for the first time 99 years ago 29th of June 1921.The old girl didn't let me down!
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Mon Jun 29, 2020 4:50 pm
It wont let you down if you dont let it down. Very nice and I like the green.
Virtus
First Name: Paul
Post by Virtus » Mon Jun 29, 2020 4:58 pm
Thanks Dallas, I look forward to the pleasure of a "different way of driving "!
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Mon Jun 29, 2020 5:44 pm
Paul, I drive mine all the time. A chance to slow down and really enjoy the drive. I drive once or twice a week in my TT. You will become comfortable with the fact that it will get you anywhere and back. You just need more time than other vehicles. :D
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Mon Jun 29, 2020 8:59 pm
Like tonight. I drove to the firehouse for our work night.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Tue Jun 30, 2020 8:51 am
I replaced the worn-beyond-use front shackles on my Runabout. I was hoping that properly aligned perches and springs would bring the caster back to nominal. That did not work. I still have way too much caster and I need to study why before making a 4-ft bending iron.
Post by Steve Jelf » Tue Jun 30, 2020 9:09 am
Paul, don't worry about driving. I expect you'll get used to it pretty quickly. Millions of people have. With a TT you won't have to worry about going too fast. :D
Post by Steve Jelf » Wed Jul 01, 2020 10:14 am
Ended the month blasting an oil pan and a pair of engine pans.
