What is this starting crank off of?
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Jun 08, 2020 8:19 pm
I pulled this starter crank out of my pile and noticed it was longer than others that I’ve seen. It has a 1914 aluminum handle on it, but the top shaft is longer than a stock T crank. Same diameter. Any ideas?
Re: What is this starting crank off of?
Post by Allan » Mon Jun 08, 2020 8:52 pm
If a car is fitted with a Livingstone V radiator, it needs that longer crank.
Alan from down under.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Jun 08, 2020 9:03 pm
Looks just like the one I stretched 3+” to clear the Laurel lowering brackets on my speedster. Are there any wear marks that would indicate it ran in a T pan... or otherwise?
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Jun 08, 2020 9:11 pm
Yes it has wear marks from a T pan.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Jun 08, 2020 9:13 pm
Ok that makes sense regarding the Livingston , because I have one of those in my stash as well. It is a honeycomb.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Jun 08, 2020 9:15 pm
Strange...? I remember painting mine black😉
