Mirror
Topic author - Posts: 2333
- Last Name: Juhl
Mirror
Does anyone make a nice mirror that mounts to the two bolts that hold the windshield frame to the body brackets? I'm not happy with the clamp on ones I have - The angles you can set them at are limited and even though I padded the clamps with rubber they tend to move on the window frame.
This is what I have
This is what I have
paddy1998
- Last Name: Delaney
- * REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
Re: Mirror
I've had the same problem.
I hope somebody chimes in with a solution.
Moxie26
- First Name: Robert
- Last Name: Jablonski
Re: Mirror
Scott & Tim : Using the mirror you have, position mirror to your liking, then drill thru clamp bracket at windshield stanchion and insert self tapping screw to stabilize mount.
B. Callfas
- Last Name: Callfas
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1915 Runabout 1920 Touring
Re: Mirror
Cut the clamp section off and make a snug fitting angle that attaches to the pivot bracket.
- Last Name: Juhl
Re: Mirror
Steve,
I've tried everything from a piece of old innertube to a section of heavy duty rubber hose. I've glued them in, I've wired them in, they always "migrate."
The other problem is that the head only allows minimum up and down movement which makes them hard to adjust. Nonetheless, I appreciate the ideas.
Re: Mirror
Just trying to visualize your setup and the movement
If the most movement is up/down the windshield frame, then something attached to the frame above and below the mirror bracket should prevent that. Just a couple of turns of a thin strip of waterproof tape (Gorilla, other) should stop that (or hose clamps) . If you have forward back movement (wind forces) and you did all the things you said, my guess is that mirror clamp jaw profile, where you want it to be, doesn't match your window frame profile. Example like the jaws are to clamp something round and the frame is oval in its cross section or the reverse
John Codman
- Last Name: Codman
Re: Mirror
I believe that Snyder's has a much better quality mirror, but although the arm is bright metal, the mirror head is black. I have the same mirror as the OP and it vibrates so badly that it is all but unusable. I wish the head was Chrome (or even better, Nickle), but I'm about to order one anyway.
Re: Mirror
Bill Bohlen (Antique Motor Sports, I believe) produces a real nice mirror that bolts to the windshield hinge - brass or black.
- Last Name: Juhl
Re: Mirror
Anybody have a good email address for Bill Bohlen? The one on his website gets rejected.
Duey_C
- First Name: Duane
- Last Name: Cooley
Re: Mirror
Watching this closely Tim!
Bob, how's the jiggle factor on that angle/hinge mount mirror? I like that.
Tim, I did mount a mirror to one of the windshield bracket bolts on the Crappy '24. Solid as a rock.
I won't show. It's part of an early 80's white GM rectangle pickup mirror.
I really should paint it brown.
The other side hangs in the garage and IF I dared, I'd put it on the the '18. I'd paint it black this time.
