1926-27 e-brake cam lever?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sun Jun 14, 2020 1:24 am
Is the 1926-27 e-brake cam lever the same as previous years or is it something different?
Re: 1926-27 e-brake cam lever?
Post by Allan » Sun Jun 14, 2020 1:53 am
It's different, longer.
Allan from down under
Post by Mark Gregush » Sun Jun 14, 2020 9:20 am
And only uses 1 rivet to hold in place, 1925 back used 2.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sun Jun 14, 2020 10:50 am
Not seeing it on Lang's, am I missing something?
Post by RajoRacer » Sun Jun 14, 2020 10:52 am
What are you referring to as a "1926-27 e-brake cam lever" ?
Post by Mark Gregush » Sun Jun 14, 2020 10:57 am
Don't think they are reproduced so you are not missing anything. Place an ad in the classifieds or call them and ask if they have any. Oh, they use a larger diameter/longer rivet, those you can get. If you get used ones or if yours have worn clevis pin holes, you can braze them up and renew.
