Engine Cradle v. Engine Stand
paddy1998
Topic author - Posts: 190
- Last Name: Delaney
- * REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
As a result of the seized head bolt follies of the past week (viewtopic.php?f=2&t=13537 I'm going to have to pull the engine.
Because this is the first time I'll be doing this I'll need to acquire some equipment, specifically an engine stand or cradle.
It is unlikely I will ever pull the engine out of any other car besides a Model T.
I'm going to put in new valves, clean up the top, maybe a new fan bearing, and possibly a new clutch spring and clutch discs.
I'm partial to the cradle because of the space limitations of my garage, but will I have sufficient access to remove the clutch spring and drive plate to inspect the clutch discs and lug shoes (1926) while it's still in the crankcase? Seems like not, but I don't know.
Any thoughts would be appreciated.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Engine Cradle v. Engine Stand
A conventional engine stand that rotates is best. It will permit working on the top, the bottom, and turning it on its nose to set the mag ring gap.
frontyboy
- First Name: dick
- Last Name: dock
- * REQUIRED* Type and Year of Model Ts owned: T sprint cars
Lang's sell an adapter for a inexpensive motor stand that is designed to fit a model t motor. This will allow you to rotate your motor 360 degrees for ease in working on it.
frontyboy
frontyboy
Altair
- First Name: David
- Last Name: Menzies
- Board Member Since: 2012
I made a wood engine cradle that was designed so that I could turn the engine over and place it in upside down. I would put it on the floor and gingerly turn it over and pick it up replace it upside down. This is not as convenient as a fancy engine stand but it only takes a few minutes longer, and you are never in a hurry working on an engine, slow and methodical gets the job done right.
Yes, you want the pan off when you work on the transmission. You also want the stand to rotate so you can turn the engine nose down to work on the transmission and magneto.
Kaiser
- First Name: Leo
- Last Name: van Stirum
One of these will work best for your needs, together with Lang's adapterplate you have the best combination.
Be sure to get the version with four casters, the three wheeled version in not stable enough for the big lump of a T engine and trans.
Added bonus: it can be taken apart for storage if space is a problem.
As usual i have no connection to the seller, the picture is just for illustrative purposes..
- Attachments
- image.png (36.35 KiB) Viewed 6144 times
Leo van Stirum, Netherlands
paddy1998
Hey thanks for all the advice.
I picked up a used Harbor Freight 1,000 lb stand for cheap from somebody that just wanted it gone and ordered the adapter plate.
Now keeping an eye out for a hoist while I wait for the adapter plate to arrive.
kelly mt
- Last Name: Kelly
I really like this engine stand. Very stable. As far as cradle I use three jack stands.
Duey_C
- First Name: Duane
- Last Name: Cooley
Nice score on the used stand Scott.
Pat, cute 12-20? in the background.
