Hi,
We rework a Ford TT Ruckstell rear axle. We have the "The Ruckstell Axle" book but can't find any information about the bearing play. Can someone give us some information? Thanks Stefan[image][/image]
Bearing clearance on Ford TT axle
bigbull
Topic author - Posts: 1
- First Name: Stephan
- Last Name: Schaller
- * REQUIRED* Type and Year of Model Ts owned: TT Truck 1925 and Touring 1923
- Attachments
- Driveschaft.JPG (50.6 KiB) Viewed 1529 times
- Distanz.JPG (38.34 KiB) Viewed 1529 times
- Mutter.JPG (38.67 KiB) Viewed 1529 times
HPetrino
- First Name: Henry
- Last Name: Petrino
- * REQUIRED* Type and Year of Model Ts owned: 1918 TT
Re: Bearing clearance on Ford TT axle
I don't believe there are any clearance guidelines or "settings". I just ran mine tight enough to eliminate excessive movement being sure everything moved freely and that's it. I may be wrong, but it's been working fine for 18 years since had it apart.
