Clean brake shoe/Lining
Ben Umberger
First Name: Ben
Last Name: Umberger
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 20 Touring, 27 Touring
Post by Ben Umberger » Mon Jun 29, 2020 9:30 pm
Is there any way to reasonably clean the break shoe and lining?
What would you use to clean the inside of the drum?
Ben
First Name: Dallas
Last Name: Landers
Re: Clean brake shoe/Lining
Post by Dallas Landers » Mon Jun 29, 2020 9:33 pm
I soaked and scrubbed shoes in gas. Used brake cleaner to finish. Same with drums to get all the sticky gunk off while rebuilding the rear axle on my 26 RPU.
Ben Umberger
First Name: Ben
Last Name: Umberger
Post by Ben Umberger » Mon Jun 29, 2020 10:57 pm
I'll try that overnight
Last Name: Hjortnaes
Post by DHort » Tue Jun 30, 2020 12:36 am
Kerosene. Less flammable.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Tue Jun 30, 2020 3:20 am
I've used E-85 as it's 60-85% ethyl alcohol, not as flammable (I presume) as gasoline, and it's cheap. when tossed out and lit, it burns with a much less intense flame than gasoline. Just my opinion, however
jiminbartow
Last Name: Patrick
Post by jiminbartow » Tue Jun 30, 2020 9:49 am
I have always been taught to never use gasoline as a soaking/cleaning agent. It is just too flammable and dangerous and the fumes go very far. If the fumes happen to find an ignition source, such as the pilot light of a floor mounted water heater, it can ruin your day, if not your life. As a solvent for cleaning oil based deposits from parts, I have found nothing better than lacquer thinner but it is a hot solvent and should not be used to clean painted parts unless you want to remove the paint. When soaking in any kind of flammable solvent, it is always a good idea to cover the container to keep the fumes and solvent contained. To keep your wife happy, instead of using your wife’s cooking pots for cleaning parts, you can find very nice sets of stainless steel parts cleaning containers in various sizes in the form of cooking pot sets, with form fitting tops at Walmart. You’ll be surprised at how much you use them around your shop. Jim Patrick
Post by RajoRacer » Tue Jun 30, 2020 11:06 am
That's why they make Brakleen !
critterpainter
First Name: Bill
Last Name: Dodd
* REQUIRED* Type and Year of Model Ts owned: 14 T Touring
Post by critterpainter » Tue Jun 30, 2020 11:20 am
As a last step in de-greasing use Super Clean or Purple Power or a cleaner of that sort. It Will remove all traces of oils left by other cleaners or gasoline.
14 Touring
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Tue Jun 30, 2020 12:02 pm
I should have noted to clean parts with gasoline " OUTSIDE". Brake clean after. A good scrub with Dawn dishsoap would probably work also.
Virtus
First Name: Paul
Last Name: Robertson
* REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
Post by Virtus » Tue Jun 30, 2020 3:46 pm
BMW in Europe sell an aerosol brake cleaner. I used it recently on my TT rear shoes and drum. Best cleaner I have used, I thought the shoes were beyond redemption. Would highly recommend.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Tue Jun 30, 2020 4:18 pm
Whatever you use, be SURE to wear gloves designed for that purpose! Any of the products you're likely to use are quite toxic and it's best to avoid direct contact with your skin.
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Post by Mustang1964s » Tue Jun 30, 2020 4:39 pm
My go to is LA's Awesome Cleaner - 20 oz - Dollar General.
I put it in a plastic container with lid. Let it soak over night. Pull the part. Scrub with wire brush, rinse and repeat.
