How do you remove the hub cotter keys? The keys rear and front they seem way down inside the hubs
Bob
Dayton wire wheel info
E THOMAS
- First Name: Erik
- Last Name: Thomas
- * REQUIRED* Type and Year of Model Ts owned: 1925 roadster pick up
- Board Member Since: 2014
Re: Dayton wire wheel info
On Rudge spline drive hubs, there is usually a small hole in the side, sometimes covered with a small screw.
Nv Bob
Topic author - Posts: 799
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
These are 6 pin drive 30x3.5 there is no hole or screw in the hub
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
The Buffalo hubs have the same condition...
Use a little tool, and a lotta patience!
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Add a 1/4" diameter thru hole in the hub that lines up with the keyway and the cotter pin hole in the axle. The added hole won't weaken the hub. Or do as Kevin suggested and just live with it. Needle nose pliers are your friend.
Yes - LONG needle nose !!!
Nv Bob
- First Name: Bob
Thanks im going mark it and once off drill
Thanks guys
Thanks guys
