Speedometer Cable question
tom_strickling
Topic author - Posts: 448
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
If you use modern speedometer cable inside the flexible brass housing, do you need a sleeve of some type over the cable to protect the brass??
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
Re: Speedometer Cable question
Tom, on a car I have since sold, I fitted both the outer case and inner cable of a modern car inside the original housing.
Yes you in need the inner sleeve. The kits sold by the dealers come with it.tom_strickling wrote: ↑Wed Jul 08, 2020 1:05 pmIf you use modern speedometer cable inside the flexible brass housing, do you need a sleeve of some type over the cable to protect the brass??
tom_strickling
- First Name: Tom
Thanks, does anyone have a Stewart 5 foot cable they will sell. Lang's has them back ordered. Or can I just order the Stewart ends and make up my own? How?
I have both ends - drop me a note.
