Rivets
Joe R
First Name: Joe
Last Name: Rush
Rivets
Post by Joe R » Fri Jul 10, 2020 7:33 pm
Can someone tell me approximately how many, and the various sizes of rivets were used in one (1916-1921) Model T touring car?
Joe R
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Rivets
Post by Humblej » Fri Jul 10, 2020 10:11 pm
No, they are all over, too many to count. Pick a system or an assembly and there are rivets. The steering column, steering wheel, ignition switch, the frame, rear axle housing, driveshaft, top irons, floor boards, generator, headlight buckets, horn, the list goes on and on.
Re: Rivets
Post by DanTreace » Fri Jul 10, 2020 10:21 pm
The largest rivets perhaps the frame to crossmembers, and the smallest perhaps the coil point vibrator bridge rivet ;)
Re: Rivets
Post by Steve Jelf » Sat Jul 11, 2020 12:21 am
Many of the rivets used on a Model T are available from Jim Dix (Big Flats Rivet Co.). You can Google it. Some are easy, others not so much. I finally gave up trying to find a correct top iron rivet and made one myself from a bolt.
Re: Rivets
Post by Original Smith » Sat Jul 11, 2020 9:49 am
Rivets are an interesting, and necessary subject. I've always been careful on them. Some that are sometimes overlooked are the semi tubular rivets that hold the draft deflector on the floorboards of later T's. Lang's carries those. Two that are usually the wrong type are the two semi tubular rivets that hold the ignition switch together. They are very small, and the heads require resizing down to the original size.
Re: Rivets
Post by TRDxB2 » Sat Jul 11, 2020 10:08 am
Search on Lang's for a list of items containing the word "rivets". The results include tools and part kits with rivets
https://www.modeltford.com/pl.aspx?t=s& ... e=1&pp=100
