Buffalo Wheels
Michael A
First Name: Michael
Last Name: Abbott
* REQUIRED* Type and Year of Model Ts owned: 1912 C-Cab
Buffalo Wheels
Post by Michael A » Mon Jul 20, 2020 10:25 am
I recently purchased a lovely set of 5 Buffalo wheels and hubs/caps.
The caps look nickel plated.
The wrench supplied with them is like a flat piece of steel approx a foot long with two lugs protruding that fit into the holes on the cap which obviously operates the internal locking mechanism.
Previously I have seen knock on caps with the wings or caps that you would use a wrench.
I havnt seen this style of cap before and wondered if anyone could shed some light on them.
Thanks in advance.
Michael A
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Buffalo Wheels
Post by ThreePedalTapDancer » Mon Jul 20, 2020 12:15 pm
Michael A
First Name: Michael
Last Name: Abbott
Re: Buffalo Wheels
Post by Michael A » Mon Jul 20, 2020 7:53 pm
Thanks Ray
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Buffalo Wheels
Post by Kevin Pharis » Mon Jul 20, 2020 10:11 pm
The pin drive caps are a typical earlier design for the Buffalo/House wire wheels. They were replaced sometime about ‘22. There were both cast iron and brass variations of these pin drive caps, and each had their own medallion design
Tracer
First Name: Andrew
Last Name: Webb
* REQUIRED* Type and Year of Model Ts owned: 1915 Towncar 1921 Centerdoor 1913 Racer 1927 Fordor 1927 Tudor 1926 Tudor 1927 Coupe 1926 Ute1926 Tourer 1915 Town Car
Re: Buffalo Wheels
Post by Tracer » Tue Jul 21, 2020 5:23 am
Beautiful wheels
Michael A
First Name: Michael
Last Name: Abbott
Re: Buffalo Wheels
Post by Michael A » Tue Jul 21, 2020 5:56 am
Thank you yes they are great.
My caps are in excellent condition but the face didn’t have any decal or a recess for one.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Buffalo Wheels
Post by Kevin Pharis » Tue Jul 21, 2020 10:13 am
There is a sight recess near the outer perimeter of your caps to accept the thin sheet metal medallion. If the brass caps are similar design to the iron caps (I don’t have any brass caps to confirm), the medallion should be held on by the same 2 rivets that capture the latching mechanism.
Your rivet holes may have been covered up during the plating process...? Not sure if anybody is reproducing the medallions either...?
Michael A
First Name: Michael
Last Name: Abbott
Re: Buffalo Wheels
Post by Michael A » Tue Jul 21, 2020 8:58 pm
Thanks Kevin, pm sent.
schwabd1
First Name: David
Last Name: Schwab
Re: Buffalo Wheels
Post by schwabd1 » Tue Jul 21, 2020 10:14 pm
The medallion for the center was reproduced at some point. I bought a set from one of the regular suppliers about 15 hears ago.... I don't remember which one. They weren't in their catalog, but on a phone call they remembered having some in a drawer somewhere, They called back and advised they had both the left and right. No idea where they got them or who made them. The only issue was they were flat, and they needed to be pressed into a "dome" to follow the curve of the cap. I made a jig to form the curve and they fit perfectly. So somebody out there probably has a set or two stashed away somewhere.
Michael A
First Name: Michael
Last Name: Abbott
Re: Buffalo Wheels
Post by Michael A » Wed Jul 22, 2020 10:26 am
Michael A
First Name: Michael
Last Name: Abbott
Re: Buffalo Wheels
Post by Michael A » Wed Jul 22, 2020 10:31 am
Finally pictures uploaded.
Here is my caps slightly different to the ones Kevin provided. Maybe mine have been remade.
Michael A
