Good morning, I have a 1911 touring that has firewall to windshield brackets that are steel. There is light surface rust, and the firewall is weathered so it looks original.
Is this correct? From photos of restored cars, they all look brass. Were they originally brass plated?
Any info appreciated, Mike
Firewall to windshield brackets
Michael Paul
Topic author - Posts: 428
- First Name: Michael
- Last Name: Paul
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring, 1909 touring
- First Name: Keith
- Last Name: Townsend
Re: Firewall to windshield brackets
Michael-
Yes. My original 1911 firewall to windshield brackets are brass plated steel.
Original brass plating is very poor on those brackets, their respective mounting hardware, and spark & Throttle rods.
Reproduction brackets are solid brass.
-Keith
-Keith
Michael Paul
- Last Name: Paul
Thank you Keith, it's what I suspected. Do those small brush plating kits work well?
Walter Higgins
- First Name: Walter
- Last Name: Higgins
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
Lots of parts like that, screws / bolts included, were brass plated steel and for good reason. Keep what you've got. The solid brass reproductions of those are dimensionally incorrect.
Altair
- First Name: David
- Last Name: Menzies
- Board Member Since: 2012
I have these brackets in my stash and I don't know exactly what they fit (some early teens). These brackets are cast brass and they came out of an old collapsing barn with a brass windshield frame and the wood attached. From earlier comments they are most likely repros.
- First Name: Keith
That windshield spacer board looks like the type used in 1909.
