Texas T water pump
Topic author - Posts: 270
- First Name: Dick
- Last Name: Cruickshank
- * REQUIRED* Type and Year of Model Ts owned: 1912 Depot Hack, 1916 Touring
Texas T water pump
Can the bearing and seal be replaced on the Texas T water pump?
- Last Name: Delaney
- * REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
Re: Texas T water pump
Well, the instructions say that of you disassemble the pump it will leak and void the warranty.
On the other hand, the warranty is only 90 days, so there's that.
- First Name: Henry
- Last Name: Lee
GOOD ONE Scott! LOL!
I believe there is a hidden retaining set screw, look for some gasket sealer hiding it. It slides out thru the front. Hope this Helps.
