Oil line
Bill Thompson
First Name: Bill
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 Tudor sedan
Oil line
Post by Bill Thompson » Fri Aug 07, 2020 11:37 am
Which hole does the outside oil line use?
Last Name: House
Re: Oil line
Post by George House » Fri Aug 07, 2020 1:17 pm
Assuming you use the mag post accy outside oil line like I use, it’s the bolt hole immediately to the left of the crankshaft & pully.
GrandpaFord
First Name: Neil
Last Name: Kaminar
Re: Oil line
Post by GrandpaFord » Sat Aug 08, 2020 11:29 am
The outside oil line I used required holes to be cut in the hogs head and the side of the pan near the front. I did all the work when the engine was apart for an overhaul. I added the oil line that allows an optional oil filter which has trapped lots of crap. My oil now stays clean. The oil filter that is used is actually one used for a hydraulic system. It does not have the check valve that regular oil filters have. The check valve adds too much restriction so that no oil will flow.
TeveS-Nor Cal
Last Name: Straw
Re: Oil line
Post by TeveS-Nor Cal » Sat Aug 08, 2020 3:37 pm
More info on the oil filter, etc. please
NHUSA
First Name: Fred
Last Name: Dimock
* REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Re: Oil line
Post by NHUSA » Sun Aug 09, 2020 8:40 pm
Bill, I use the outside oil line that is described by George House.
NH - Where I used to live - not the carburetor ! :lol:
