Fan pulley shaft problem
BarryB
First Name: Barry
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 roadster
Post by BarryB » Fri Aug 07, 2020 6:21 pm
This is probably a dumb newbie problem...I have a 26 roadster and am replacing the fan pulley shaft. When I tighten the shaft nut, the pulley won't spin and if I loosen the nut til the pulley spins it has a lot of wobble and then just tightens up. What am I doing wrong?? Thanks!
First Name: Henry
Last Name: Lee
Re: Fan pulley shaft problem
Post by Henry K. Lee » Fri Aug 07, 2020 6:30 pm
Over the years your stop shoulder on the bolt shank is probably gone or the cam washer has been crushed. You can either hold the back of the shaft by a flat spot and then tighten the nut. Best to add a star washer to prevent it from coming loose.
Hope this Helps,
jab35
Last Name: Bartsch
Post by jab35 » Fri Aug 07, 2020 6:42 pm
Barry: This might help. app.php/gallery/image/1124
Post by Allan » Fri Aug 07, 2020 8:47 pm
Barry, the step in the shaft is meant to screw into the holder up to the step. The nut on the end is then just a locknut. If your fan is binding with the new shaft, the face on the bushings needs to be sanded/filed back somewhat to get clearance for the fan.
Hope this helps,
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Aug 07, 2020 8:50 pm
Dah on me.., Thanks Allan! My allergies got me so jacked up at the moment!
Post by Mark Gregush » Sat Aug 08, 2020 12:11 pm
Were the bushings replaced or just the shaft? If the bushings were not, then you now have a new shaft in a worn hole.
