Photos
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
BLB27
First Name: Bruce
Last Name: Brakke
Photos
Post by BLB27 » Sat Aug 08, 2020 1:00 am
Where can I find instructions how to post photos?
Re: Photos
Post by Mark Gregush » Sat Aug 08, 2020 3:24 pm
Under the message box, click on "Attachments", when that opens click on "files". That opens the window to load photos from your files. When you find the ones you want to post hold the "Ctrl" key down and pick the ones you want to load (up to 5 per posting). After you have picked the ones you want to load release the "Ctrl" button. Then click "open" in the file upload window. That window will close and you should see the files being loaded on the page. If the photos are loaded, it will show green or not loaded. If you have more then 5 to load, don't start a new subject, load them as replies to the first posting.
Hope that helps.
Mark
Last Name: Strange
Re: Photos
Post by CudaMan » Sat Aug 08, 2020 3:34 pm
I think you can also just click and drag photos into the text box, like this. Hey, it worked! :)
