pesty skip found
Chuck Stevens
First Name: chuck
Last Name: stevens
* REQUIRED* Type and Year of Model Ts owned: 1921 roadster
pesty skip found
Post by Chuck Stevens » Sat Aug 08, 2020 7:15 am
My 21 roadster has had a skip off and on since I've had it. Yesterday I turned on the ign and hand turned it to each firing point. The garage was dark and I saw a spark in the wrong place, The copper spark plug wire had come loose from the brass end that connects it to the coil. They are soldered originally. A drop of solder and we were back in business. I would have thought the small gap would have no effect on firing the plug. So turn off your lights and see what you see. It made my day, Chuck.
Re: pesty skip found
Post by John kuehn » Sat Aug 08, 2020 8:45 am
That’s good that you found it!
The simple fix things are usually the hardest to find sometimes. I’ll bet that’s happened to more than few T’s.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Sat Aug 08, 2020 1:12 pm
My wife sez I do some of my best work in the dark!!!!!
frontyboy :lol:
