The advice of E. B. White and the Model T.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Sat Aug 08, 2020 12:20 pm
I saw that there was a posting of the E. B. White tale of the Model T, “Farewell, My Lovely!” I wonder how many actually seeing the posting have read the text. Certainly the information is valuable to a new owner, or one wishing to own a Model T. And if read before ownership or even after purchasing, it would help answer some questions that appear on the forum.
First off, White does point out the cultural significance of the Model T. “The last Model T was built in 1927, and the car is fading from what scholars call the American scene—which is an understatement, because to a few million people who grew up with it, the old Ford practically was the American scene.” Those who had mentors, or remember who E. B. White was, or grew up working on the relics are now far and few. And now new "T" owners are picking up the pieces. And those that have discovered, that with enough pieces, it is not difficult to build a sort of Model T.
There is a Ford owner’s manual, explaining the principal of Model T Construction and Operation. And there is the E. B. White explanation of what makes the “T” click. White points out, “The Ford driver flew blind. He didn’t know the temperature of his engine, the speed of his car, the amount of his fuel or the pressure of his oil (the old Ford lubricated itself by what was amiably described as the “splash system”). A speedometer cost money and was an extra, like a windshield-wiper. The dashboard of the early models was bare save for an ignition key; later models, grown effete, boasted an ammeter which pulsated alarmingly with the throbbing of the car. Under the dash was a box of coils, with vibrators which you adjusted, or thought you adjusted. Whatever the driver learned of his motor, he learned not through instruments but through sudden developments. I remember that the timer was one of the vital organs about which there was ample doctrine. When everything else had been checked, you “had a look” at the timer. It was an extravagantly odd little device, simple in construction, mysterious in function. It contained a roller, held by a spring, and there were four contact points on the inside of the case against which, many people believed, the roller rolled. I have had a timer apart on a sick Ford many times, but I never really knew what I was up to—I was just showing off before God. There were almost as many schools of thought as there were timers. Some people, when things went wrong, just clenched their teeth and gave the timer a smart crack with a wrench. Other people opened it up and blew on it. There was a school that held that the timer needed large amounts of oil; they fixed it by frequent baptism. And there was a school that was positive it was meant to run dry as a bone; these people were continually taking it off and wiping it. I remember once spitting into a timer; not in anger, but in a spirit of research. You see, the Model T driver moved in the realm of metaphysics. He believed his car could be hexed.” (The New Yorker. Farewell, My Lovely! By E. B. White. May 9, 1936)
