Starter Brush plate Busing question
Newtexaz
First Name: Randy
Last Name: Clemens
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1926 Roadster, 1927 Fordor
Post by Newtexaz » Sun Aug 09, 2020 3:11 pm
Has anyone else found that after replacing the Babbitt bushing in the brush end plate with one of the suppliers new brass bushings that the brass bushing holds the armature further away and the brushes don’t completely line up with the commutators? Picture below to further explain. Is this bushing supposed to be surfaced / shortened so the brush doesn’t overhang the commutators?
Randy
Re: Starter Brush plate Busing question
Post by Mark Gregush » Sun Aug 09, 2020 3:33 pm
Add thrust washers as needed to move back.
Newtexaz
First Name: Randy
Last Name: Clemens
Post by Newtexaz » Sun Aug 09, 2020 3:58 pm
Thanks Mark but the armature is all the way back against that brush plate bushing that’s why I’m wondering if I should shorten or shave down that bushing.
Newtexaz
First Name: Randy
Last Name: Clemens
Post by Newtexaz » Sun Aug 09, 2020 4:01 pm
jab35
Last Name: Bartsch
Post by jab35 » Sun Aug 09, 2020 4:10 pm
Randy: When I replaced the bushings on the Bendix end as well as the brushplate end, the Bendix end bushing collar centered the brushes correctly on the armature. I then turned/shortened the brush end spacer to fit plus giving about 0.010" end play. If you can bolt up the starter in your pic you definitely need to add thrust washers on the Bendix end and shorten the brush end spacer. best, jb
Newtexaz
First Name: Randy
Last Name: Clemens
Post by Newtexaz » Sun Aug 09, 2020 5:06 pm
Thanks Jb!
